Pause while printing from SD - gcode changes
Hi, i don't know why, but when trying to make a pause while printing from sd either the pause just doesnt pause, or it will end the print.
So my question is which is the command to pause (M25?) and how do i resume ?
What i want to do is changing the filament color, thats why i need it. I know that with the computer attached i can easily use the @pause script, but i want to do this with the SD.
  • Problem solved. I don't know why, but when i tried it again all was working as i need:
    I used:
    G91
    G1 Z20
    M117 Change filament
    M25
    M117
    G1 Z-20
    G90
  • You know in quicksettings is also a filament change wizard that works for sd and host prints. At least if configured correctly.
  • hi, I sd during the printing process to pause when I tried to go to the opposite side of the x-axis is not home jams. I 'm using Core xy printer.
