The Z axis larger prints
Hi all.
I have a problem when printing, the Z axis resizes what you print.
The configuraciond is correct 2560 steps per minute, the configuration of the pololus is also correct, but what print is larger than the model.
  • Have you measured how much z axis goes up when you say 10mm? Sounds like it has a different steps per mm then you think it has. 2560 steps per mm is for M8 with /16 substepping. Other combinations have other resolutions.
