Can't get SD card to work
Hi guys, I'm fairly new to the 3D printer world, so apologies if I miss anything obvious.
I have built a home made reprap printer but I'm having some issues with getting the SD card to initialize or mount. I can print from USB without any problem.
I am using the following;
- Arduino Mega 2560
- RAMPS 1.4
- REPRAP Pro Discount Smart Controller (tried both normal and full graphic variants
- Repetier firmware V2 (or what ever the latest version is)
- Windows 7, Arduino V1.0.6 to compile, Repetier Host
I have the SDDetect set to -1 and with that I go through the menu on the screen I have an option to mount an SD card but it just resets and nothing happens. If I change the SDDetect to 49 when the SD is plugged in all the printer does is continuously restarts.
Any help would be much appreciated.
Thanks in advance!
