G30 doesn't reverse properly
Printer: Rostock Max v2 delta
I installed latest 0.92.8 from github and configured to use Z probing. Following the setup instructions at http://www.repetier.com/documentation/repetier-firmware/z-probing/ G31 shows correct state of the Z probe switch when triggered.
I tested G30 by triggering the Z probe by hand just to validate it. When I hit the probe, the Z motor reverses as expected but X & Y continue to move down until the effector crashes. This is a delta printer so all three motors should reverse in order to raise Z height.
What am I missing here? Configuration.h is here: http://pastebin.com/60J5PS4t
