Set up bed dimensions
I've set up the bed dimensions properly in the preferences and when it is printing everything seems to work fine.  I have issues using the manual print panel.  First, when I home the Y, it doesn't respond to positive values (I think it is reversed coordinate); I can put in negative but the coordinate stays at 0 but the print head will move.  Second, then I kill a job it dumps it past the X dump coordinate, and off the bed completely.  I tried changing the dump coordinates and it sill sends it off the bed.
Are there settings to fix this?
  • Check coordinates in manual tab after homing and compare with printer position. I guess there is a difference due to different homing positions set.
