Zmax move back after homing not working.
I seem to have things figured out to a degree. Except I can't seem to get the ZMAX endstop to move back 10 units (mm) after it homes. It just stays there and I have to move it manually. I guess it's not really a problem, but I would like to get it working. I have it setup on the X & Y and it works fine.
At first I ad a mechanical endstop and thought it may be caused by bounce to a switch to a optical. Much cleaner setup, so it will stay that way.
Anyway, below is the code. If anything jumps out...let me know. Hopefully I can get it fixed?
#define MIN_HARDWARE_ENDSTOP_Z false ///true
#define ENDSTOP_Z_MAX_INVERTING false //true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 10 //2
#define ENDSTOP_Z_BACK_ON_HOME 1 //0
  • Except you did set it to 1 I see no error. Here the code segment adding this move for cartesian printer (it is cartesian, right?).
    #if defined(ENDSTOP_Z_BACK_ON_HOME)
    // If we want to go up a bit more for some reason
            if(ENDSTOP_Z_BACK_ON_HOME > 0)
    zCorrection -= axisStepsPerMM[Z_AXIS] * ENDSTOP_Z_BACK_ON_HOME * Z_HOME_DIR;
    #endif
    #if Z_HOME_DIR < 0
    // Fix bed coating
    zCorrection += axisStepsPerMM[Z_AXIS] * Printer::zBedOffset;
    #endif
            PrintLine::moveRelativeDistanceInSteps(0,0,zCorrection,0,homingFeedrate[Z_AXIS],true,false);
    Cou could add
    Com::printFLN(PSTR("extrZSteps:"),zCorrection);
    after the PrintLine::move.. to see how many steps it goes back.
