ENDSTOP_Z_BACK_ON_HOME not moving back after home Z MAX endstop
I seem to have things figured out to a degree. Except I can't seem to get the ZMAX endstop to move back 10 units (mm) after it homes. It just stays there and I have to move it manually. I guess it's not really a problem, but I would like to get it working. I have it setup on the X & Y and it works fine.
At first I ad a mechanical endstop and thought it may be caused by bounce to a switch to a optical. Much cleaner setup, so it will stay that way.
Anyway, below is the code. If anything jumps out...let me know. Hopefully I can get it fixed?
#define MIN_HARDWARE_ENDSTOP_Z false ///true
#define ENDSTOP_Z_MAX_INVERTING false //true
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 10 //2
#define ENDSTOP_Z_BACK_ON_HOME 1  //0
