Z-Probing problems on delta printer / z-probe triggered before starting probing
I just updated to the latest 0.92.8 firmware. Motors, max end switches and z-probe are working (checked with M119). I can go to any position and issue G30 without any problems.
But when I try to autolevel with G32 I run into problems. Homing is done it moves to the first position X60 Y0. Sometimes this point is probed and it moves to the second position X0 Y60. Probing always fails here with:
 Error:z-probe triggered before starting probing.
 Error:Probing had returned errors - autoleveling canceled.
When I issue G30 on those positions, it's always executed without problems.
BTW: I upgraded from 0.92.6 and imported the old configuration.h in the online configurator. At least the ENDSTOP_Y_MAX_INVERTING etc. and Z_PROBE_ON_HIGH setting were not imported correctly! So I crashed the extruder into the bed at first... No damage though.
  • When you get this error and run M119 do you get the same high signal for z probe?
    This is a extra test to not start moving down when we already trigger. This happens normally only if you start too low, e.g. because the Z_PROBE_BED_DISTANCE was too low and you started higher, or you started below that value.
    It can also happen if you have mechanical switches that normally unset at a different position then being set. So if they trigger at 3mm they might untrigger at 6mm. If you go not up to at least 6mm in this case you would get that error on the next measurement.
    Hard to say what is happend from remote but that is when it should trigger the message,
    Regarding the config upgrade, do you have the 0.92.6 config so I can test the upgrade error. Can currently not imagine where it would go wrong.
  • decdec
    edited February 2016
    I don't think Z_PROBE_BED_DISTANCE is an issue, as the probe is always above the bed.
    I observed a strange behaviour. I send G32 and the first point was probed. The second point issued the error message. Sending a M119 showed that the Z probe was still triggered at a high level. But the actual hardware was not triggered. It was reset after homing.
    I then retried G32 and it failed on the first point. But M119 shows low level for z probe now. G30 still works.
    Any thoughts?
    Config file from 0.92.6 is two posts below.
  • Ok, my bad. The wire broke at the solder joint. After resoldering G32 works.
    along with Repetier-Firmware. If not, see .
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
    generator: http://www.repetier.com/firmware/v092/
    as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    // Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
    // If it is incompatible you will get compiler errors about write functions not beeing compatible!
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL -1
    #define BLUETOOTH_BAUD 115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 3
    #define XAXIS_STEPS_PER_MM 100.12
    #define YAXIS_STEPS_PER_MM 100.12
    #define ZAXIS_STEPS_PER_MM 100.12
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 218
    #define EXT0_INVERSE 1
    #define EXT0_ENABLE_ON 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 3
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN_PIN
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 0
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 3
    #define EXTRUDE_MAXLENGTH 160
    #define USE_GENERIC_THERMISTORTABLE_1
    #define GENERIC_THERM1_T0 25
    #define GENERIC_THERM1_R0 100000
    #define GENERIC_THERM1_BETA 3950
    #define GENERIC_THERM1_MIN_TEMP -20
    #define GENERIC_THERM1_MAX_TEMP 300
    #define GENERIC_THERM1_R1 0
    #define GENERIC_THERM1_R2 4700
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 97
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ## Laser configuration ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ## CNC configuration ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 5
    #define ENDSTOP_X_BACK_ON_HOME 0
    #define ENDSTOP_Y_BACK_ON_HOME 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 200
    #define Y_MAX_LENGTH 200
    #define Z_MAX_LENGTH 280
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_CORRECTION_R 60
    // ## Movement settings ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_DIAGONAL_ROD 219 // mm
    #define DELTA_ALPHA_A 210
    #define DELTA_ALPHA_B 330
    #define DELTA_ALPHA_C 90
    #define DELTA_MAX_RADIUS 60
    #define ROD_RADIUS 97
    #define PRINTER_RADIUS 97
    #define DELTA_HOME_ON_POWER 0
    #define STEP_COUNTER
    #define DELTA_FLOOR_SAFETY_MARGIN_MM 15
    //#define SOFTWARE_LEVELING
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 200
    #define MAX_FEEDRATE_Y 200
    #define MAX_FEEDRATE_Z 200
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 40
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define USE_ADVANCE 0
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 1
    #undef PS_ON_PIN
    #define PS_ON_PIN -1
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P S / ServoID = 0..3 pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS -1
    #define SERVO1_NEUTRAL_POS -1
    #define SERVO2_NEUTRAL_POS -1
    #define SERVO3_NEUTRAL_POS -1
    #define UI_SERVO_CONTROL 0
    #define FEATURE_WATCHDOG 0
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 10
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 3
    #define Z_PROBE_HEIGHT -0.25
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 60
    #define Z_PROBE_Y1 0
    #define Z_PROBE_X2 0
    #define Z_PROBE_Y2 60
    #define Z_PROBE_X3 -40
    #define Z_PROBE_Y3 -40
    #define FEATURE_AXISCOMP 1
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 2
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define UI_ANIMATION 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA 190
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS 240
    #define UI_SET_MIN_HEATED_BED_TEMP 0
    #define NUM_MOTOR_DRIVERS 0
    #endif
    "editMode": 2,
    "processor": 0,
    "baudrate": 115200,
    "bluetoothSerial": -1,
    "bluetoothBaudrate": 115200,
    "xStepsPerMM": 100.12,
    "yStepsPerMM": 100.12,
    "zStepsPerMM": 100.12,
    "xInvert": 0,
    "xInvertEnable": 0,
    "eepromMode": 1,
    "yInvert": 0,
    "yInvertEnable": 0,
    "zInvert": 0,
    "zInvertEnable": 0,
    "extruder": [
    "id": 0,
    "heatManager": 3,
    "pidDriveMin": 40,
    "pidDriveMax": 230,
    "pidMax": 255,
    "sensorType": 8,
    "sensorPin": "TEMP_0_PIN",
    "heaterPin": "HEATER_0_PIN",
    "maxFeedrate": 50,
    "startFeedrate": 20,
    "invert": "1",
    "invertEnable": "0",
    "acceleration": 5000,
    "watchPeriod": 1,
    "pidP": 7,
    "pidI": 2,
    "pidD": 40,
    "advanceK": 0,
    "advanceL": 0,
    "waitRetractTemp": 150,
    "waitRetractUnits": 0,
    "waitRetract": 0,
    "stepsPerMM": 218,
    "coolerPin": "ORIG_FAN_PIN",
    "coolerSpeed": 255,
    "selectCommands": "",
    "deselectCommands": "",
    "xOffset": 0,
    "yOffset": 0,
    "zOffset": 0,
    "xOffsetSteps": 0,
    "yOffsetSteps": 0,
    "zOffsetSteps": 0,
    "stepper": {
    "name": "Extruder 0",
    "step": "ORIG_E0_STEP_PIN",
    "dir": "ORIG_E0_DIR_PIN",
    "advanceBacklashSteps": 0,
    "decoupleTestPeriod": 12,
    "jamPin": -1,
    "jamPullup": "0"
    "uiLanguage": 0,
    "uiController": 0,
    "xMinEndstop": 0,
    "yMinEndstop": 0,
    "zMinEndstop": 0,
    "xMaxEndstop": 1,
    "yMaxEndstop": 1,
    "zMaxEndstop": 1,
    "motherboard": 33,
    "driveSystem": 3,
    "xMaxSpeed": 200,
    "xHomingSpeed": 40,
    "xTravelAcceleration": 1000,
    "xPrintAcceleration": 1000,
    "yMaxSpeed": 200,
    "yHomingSpeed": 40,
    "yTravelAcceleration": 1000,
    "yPrintAcceleration": 1000,
    "zMaxSpeed": 200,
    "zHomingSpeed": 40,
    "zTravelAcceleration": 1000,
    "zPrintAcceleration": 1000,
    "xMotor": {
    "name": "X motor",
    "step": "ORIG_X_STEP_PIN",
    "dir": "ORIG_X_DIR_PIN",
    "enable": "ORIG_X_ENABLE_PIN"
    "yMotor": {
    "name": "Y motor",
    "step": "ORIG_Y_STEP_PIN",
    "dir": "ORIG_Y_DIR_PIN",
    "enable": "ORIG_Y_ENABLE_PIN"
    "zMotor": {
    "name": "Z motor",
    "step": "ORIG_Z_STEP_PIN",
    "dir": "ORIG_Z_DIR_PIN",
    "enable": "ORIG_Z_ENABLE_PIN"
    "enableBacklash": "0",
    "backlashX": 0,
    "backlashY": 0,
    "backlashZ": 0,
    "stepperInactiveTime": 360,
    "maxInactiveTime": 0,
    "xMinPos": 0,
    "yMinPos": 0,
    "zMinPos": 0,
    "xLength": 200,
    "yLength": 200,
    "zLength": 280,
    "alwaysCheckEndstops": "1",
    "disableX": "0",
    "disableY": "0",
    "disableZ": "0",
    "disableE": "0",
    "xHomeDir": "-1",
    "yHomeDir": "-1",
    "zHomeDir": 1,
    "xEndstopBack": 0,
    "yEndstopBack": 0,
    "zEndstopBack": 0,
    "deltaDiagonalRod": 219,
    "deltaHorizontalRadius": 97,
    "deltaAlphaA": 210,
    "deltaAlphaB": 330,
    "deltaAlphaC": 90,
    "deltaDiagonalCorrA": 0,
    "deltaDiagonalCorrB": 0,
    "deltaDiagonalCorrC": 0,
    "deltaMaxRadius": 60,
    "deltaRadiusCorrA": 0,
    "deltaRadiusCorrB": 0,
    "deltaRadiusCorrC": 0,
    "deltaXOffsetSteps": 0,
    "deltaYOffsetSteps": 0,
    "deltaZOffsetSteps": 0,
    "deltaSegmentsPerLine": 24,
    "stepperHighDelay": 0,
    "directionDelay": 0,
    "allowQuadstepping": "1",
    "doubleStepDelay": 0,
    "maxJerk": 20,
    "maxZJerk": 0.3,
    "moveCacheSize": 16,
    "moveCacheLow": 10,
    "lowTicksPerMove": 250000,
    "enablePowerOnStartup": "1",
    "echoOnExecute": "1",
    "sendWaits": "1",
    "ackWithLineNumber": "1",
    "killMethod": 1,
    "useAdvance": "0",
    "useQuadraticAdvance": "0",
    "powerInverting": 0,
    "mirrorX": 0,
    "mirrorXMotor": {
    "name": "Extruder 1",
    "step": "ORIG_E1_STEP_PIN",
    "dir": "ORIG_E1_DIR_PIN",
    "mirrorY": 0,
    "mirrorYMotor": {
    "mirrorZ": 0,
    "mirrorZMotor": {
    "mirrorZ3": "0",
    "mirrorZ3Motor": {
    "name": "Extruder 2",
    "step": "ORIG_E2_STEP_PIN",
    "dir": "ORIG_E2_DIR_PIN",
    "dittoPrinting": "0",
    "featureServos": "0",
    "servo0Pin": 11,
    "servo1Pin": -1,
    "servo2Pin": -1,
    "servo3Pin": -1,
    "featureWatchdog": "0",
    "hasHeatedBed": "1",
    "enableZProbing": "1",
    "extrudeMaxLength": 160,
    "featureController": 2,
    "uiPrinterName": "RepRap",
    "uiPrinterCompany": "Home made",
    "uiPagesDuration": 4000,
    "uiAnimation": "1",
    "uiDisablePageswitch": "1",
    "uiAutoReturnAfter": 30000,
    "featureKeys": "0",
    "uiEncoderSpeed": 1,
    "uiReverseEncoder": "0",
    "uiKeyBouncetime": 10,
    "uiKeyFirstRepeat": 500,
    "uiKeyReduceRepeat": 50,
    "uiKeyMinRepeat": 50,
    "featureBeeper": "0",
    "uiPresetBedTempPLA": 60,
    "uiPresetBedABS": 110,
    "uiPresetExtruderPLA": 190,
    "uiPresetExtruderABS": 240,
    "uiMinHeatedBed": 0,
    "uiMaxHeatedBed": 120,
    "uiMinEtxruderTemp": 170,
    "uiMaxExtruderTemp": 260,
    "uiExtruderFeedrate": 2,
    "maxBedTemperature": 120,
    "bedSensorType": 97,
    "bedSensorPin": "TEMP_1_PIN",
    "bedHeatManager": 0,
    "bedUpdateInterval": 5000,
    "bedPidDriveMin": 80,
    "bedPidDriveMax": 255,
    "bedPidP": 196,
    "bedPidI": 33,
    "bedPidD": 290,
    "bedPidMax": 255,
    "bedDecoupleTestPeriod": 300,
    "caseLightPin": -1,
    "caseLightDefaultOn": "1",
    "bedSkipIfWithin": 3,
    "gen1T0": 25,
    "gen1R0": 100000,
    "gen1Beta": 3950,
    "gen1MinTemp": -20,
    "gen1MaxTemp": 300,
    "gen1R1": 0,
    "gen1R2": 4700,
    "gen2T0": 25,
    "gen2R0": 100000,
    "gen2Beta": 4036,
    "gen2MinTemp": -20,
    "gen2MaxTemp": 300,
    "gen2R1": 0,
    "gen2R2": 4700,
    "gen3T0": 25,
    "gen3R0": 100000,
    "gen3Beta": 4036,
    "gen3MinTemp": -20,
    "gen3MaxTemp": 300,
    "gen3R1": 0,
    "gen3R2": 4700,
    "userTable0": {
    "r1": 0,
    "r2": 4700,
    "temps": [],
    "numEntries": 0
    "userTable1": {
    "r1": 0,
    "r2": 4700,
    "temps": [],
    "numEntries": 0
    "userTable2": {
    "r1": 0,
    "r2": 4700,
    "temps": [],
    "numEntries": 0
    "tempHysteresis": 3,
    "pidControlRange": 20,
    "skipM109Within": 2,
    "extruderFanCoolTemp": 50,
    "minTemp": 150,
    "maxTemp": 275,
    "minDefectTemp": -10,
    "maxDefectTemp": 290,
    "arcSupport": "1",
    "forceChecksum": "0",
    "sdExtendedDir": "1",
    "featureFanControl": "1",
    "fanPin": "ORIG_FAN_PIN",
    "scalePidToMax": 0,
    "zProbePin": "ORIG_Z_MIN_PIN",
    "zProbeBedDistance": 10,
    "zProbePullup": "1",
    "zProbeOnHigh": "0",
    "zProbeXOffset": 0,
    "zProbeYOffset": 0,
    "zProbeWaitBeforeTest": "0",
    "zProbeSpeed": 10,
    "zProbeXYSpeed": 150,
    "zProbeHeight": -0.25,
    "zProbeStartScript": "",
    "zProbeFinishedScript": "",
    "featureAutolevel": "1",
    "zProbeX1": 60,
    "zProbeY1": 0,
    "zProbeX2": 0,
    "zProbeY2": 60,
    "zProbeX3": -40,
    "zProbeY3": -40,
    "zProbeSwitchingDistance": 1,
    "zProbeRepetitions": 3,
    "sdSupport": "0",
    "sdCardDetectPin": -1,
    "sdCardDetectInverted": "0",
    "uiStartScreenDelay": 1000,
    "xEndstopBackMove": 5,
    "yEndstopBackMove": 5,
    "zEndstopBackMove": 5,
    "xEndstopRetestFactor": 3,
    "yEndstopRetestFactor": 3,
    "zEndstopRetestFactor": 3,
    "xMinPin": "ORIG_X_MIN_PIN",
    "yMinPin": "ORIG_Y_MIN_PIN",
    "zMinPin": "ORIG_Z_MIN_PIN",
    "xMaxPin": "ORIG_X_MAX_PIN",
    "yMaxPin": "ORIG_Y_MAX_PIN",
    "zMaxPin": "ORIG_Z_MAX_PIN",
    "deltaHomeOnPower": "0",
    "fanBoardPin": -1,
    "heaterPWMSpeed": 0,
    "featureBabystepping": "1",
    "babystepMultiplicator": 1,
    "pdmForHeater": "0",
    "pdmForCooler": "0",
    "psOn": -1,
    "mixingExtruder": "0",
    "featureAxisComp": "1",
    "axisCompTanXY": 0,
    "axisCompTanXZ": 0,
    "axisCompTanYZ": 0,
    "retractOnPause": 2,
    "pauseStartCommands": "",
    "pauseEndCommands": "",
    "distortionCorrection": "1",
    "distortionCorrectionR": 60,
    "distortionPermanent": "1",
    "distortionEndDegrade": 1,
    "sdRunOnStop": "",
    "featureRetraction": "1",
    "autoretractEnabled": "0",
    "retractionLength": 3,
    "retractionLongLength": 13,
    "retractionSpeed": 40,
    "retractionZLift": 0,
    "retractionUndoSpeed": 20,
    "filamentChangeXPos": 0,
    "filamentChangeYPos": 0,
    "filamentChangeZAdd": 2,
    "filamentChangeRehome": 1,
    "fanKickstart": 200,
    "servo0StartPos": -1,
    "servo1StartPos": -1,
    "servo2StartPos": -1,
    "servo3StartPos": -1,
    "uiDynamicEncoderSpeed": "1",
    "uiServoControl": 0,
    "killIfSensorDefect": "0",
    "jamSteps": 220,
    "jamSlowdownSteps": 320,
    "jamSlowdownTo": 70,
    "jamErrorSteps": 500,
    "jamMinSteps": 10,
    "jamAction": 0,
    "primaryPort": 0,
    "numMotorDrivers": 0,
    "motorDrivers": [
    "t": "None",
    "s": "",
    "invertDirection": "0",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "t": "None",
    "s": "",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "t": "None",
    "s": "",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "t": "None",
    "s": "",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "t": "None",
    "s": "",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "t": "None",
    "s": "",
    "stepsPerMM": 100,
    "speed": 10,
    "dirPin": -1,
    "stepPin": -1,
    "enablePin": -1
    "manualConfig": "",
    "zHomeMinTemperature": 0,
    "zHomeXPos": 999999,
    "zHomeYPos": 999999,
    "zHomeHeatHeight": 20,
    "zHomeHeatAll": "1",
    "zProbeZOffsetMode": 0,
    "zProbeZOffset": 0,
    "uiBedCoating": "1",
    "langEN": "1",
    "langDE": "0",
    "langNL": "0",
    "langPT": "0",
    "langIT": "0",
    "langES": "0",
    "langSE": "0",
    "langFR": "0",
    "langCZ": "0",
    "langPL": "0",
    "accelerationFactorTop": 100,
    "bendingCorrectionA": 0,
    "bendingCorrectionB": 0,
    "bendingCorrectionC": 0,
    "supportLaser": "0",
    "laserPin": -1,
    "laserOnHigh": "1",
    "defaultPrinterMode": 0,
    "supportCNC": "0",
    "cncWaitOnEnable": 300,
    "cncWaitOnDisable": 0,
    "cncEnablePin": -1,
    "cncEnableWith": "1",
    "cncDirectionPin": -1,
    "cncDirectionCW": "1",
    "startupGCode": "",
    "jsonOutput": "0",
    "hasMAX6675": false,
    "hasMAX31855": false,
    "hasGeneric1": true,
    "hasGeneric2": false,
    "hasGeneric3": false,
    "hasUser0": false,
    "hasUser1": false,
    "hasUser2": false,
    "numExtruder": 1,
    "version": 92.6,
    "primaryPortName": ""
