Issues with firmware configuration
i build a 3D printer myself, using Repetier. I have learned a lot about it and the printer is running very well.
At the moment i have 3 issues i cant solve. I was searching for some information, but couldn't find anything. I hope you can help me.
I use The Ramps 1.4 Board. The hotend is connected to D10 and T0.
Some days ago i added a heatbed on D8 and T1.
It worked very well!
Issue 1:
Today i connected the hotend fan (who was connected to 12V before) to D9
In the firmware configuration tool i set "Thermo Coupled Fan Pin" at the "Feature" page to "Fan Pin" and the "Thermo Fan Temperature Sensor Pin" to "T0".
The fan is now starting, when T0 reaches 50°C
BUT the confusing thing is, that the heatbed temperature is now reading from the extruder (T0).
In repetier it is set to T1 !
I Also tried to use T2 for heatbed thermistor, but it still shows the T0 heatbed temperature until i disable "Thermo Coupled Fan Pin"
Issue 2:
I wanted to increase the retraction and retraction undo speed of the extruder. It was set to 20mm/s before. Because i have not seen any difference using 30mm/s, i raised it to impossible 200mm/s. But still no change happens! It remains on 20mm/s.
I set the 200mm/s value in firmware, EEPROM and Slicer. But it remains on 20mm/s
Issue 3:
Also, the Z axis acceleration can't be changed. I use a gearing for Z-axis so i need around 2500 steps for 1mm in travel. I used 0,2mm/s for Z until now, but wanted to increase it.
But even if i set the acceleration to 0,001mm/s², the Z axis is at full speed from the beginning.
It also doesn't work to use 0,3mm/s or 0,4mm/s. It remains at 0,2. (Changed limit in firmware and EEPROM)
THANKS for your help, and continue your great work!
PS: It is very very confusing, that the parameters, who can be configured in EEPROM, are still visible in the firmware configuration tool, when EEPROM is actived. Have you thought about hiding the parameters?
