G33 distortion correction
I am having trouble with distortion correction. I have my Z axis height and bed level so that I can print fairly well without any correction, but larger prints start to show the distortion and I have bed adhesion problems.
When I run G33 I get a distortion map copied below..
When I attempt to print the nozzle attempts to print several mm above the print bed. When I try to verify the distortion correction manually with the paper shim the nozzle is either 1mm above the bed or it crashes into the print bed. It is not even consistent between homing for the same distortion map. It seems like when the print head gets to 0.5mm above the print head it just goes crazy.
I must have something wrong. Can you help me set this up?
I am sure the Z probe height is -5.7. I am sure the z max distance is 463.8
00:47:26.421 : Z correction disabled
00:47:30.757 : Z-probe:-1.15 X:-50.00 Y:100.00
00:47:33.043 : Z-probe:-1.01 X:0.00 Y:100.00
00:47:35.375 : Z-probe:-0.94 X:50.00 Y:100.00
00:47:38.531 : Z-probe:-1.12 X:-100.00 Y:50.00
00:47:40.829 : Z-probe:-1.02 X:-50.00 Y:50.00
00:47:43.135 : Z-probe:-1.01 X:0.00 Y:50.00
00:47:45.453 : Z-probe:-0.92 X:50.00 Y:50.00
00:47:47.841 : Z-probe:-0.79 X:100.00 Y:50.00
00:47:51.405 : Z-probe:-0.99 X:-100.00 Y:0.00
00:47:53.744 : Z-probe:-0.97 X:-50.00 Y:0.00
00:47:56.077 : Z-probe:-0.95 X:0.00 Y:0.00
00:47:58.424 : Z-probe:-0.91 X:50.00 Y:0.00
00:48:00.778 : Z-probe:-0.89 X:100.00 Y:0.00
00:48:04.351 : Z-probe:-0.89 X:-100.00 Y:-50.00
00:48:06.699 : Z-probe:-0.95 X:-50.00 Y:-50.00
00:48:09.035 : Z-probe:-0.97 X:0.00 Y:-50.00
00:48:11.390 : Z-probe:-0.92 X:50.00 Y:-50.00
00:48:13.722 : Z-probe:-0.95 X:100.00 Y:-50.00
00:48:16.940 : Z-probe:-0.89 X:-50.00 Y:-100.00
00:48:19.311 : Z-probe:-0.92 X:0.00 Y:-100.00
00:48:21.663 : Z-probe:-0.96 X:50.00 Y:-100.00
00:48:23.581 : Info:Distortion correction matrix:
00:48:23.581 : 902, 892, 881, 875, 862
00:48:23.581 : 890, 882, 881, 874, 863
00:48:23.581 : 879, 878, 876, 873, 871
00:48:23.581 : 871, 876, 878, 874, 876
00:48:23.597 : 865, 871, 874, 877, 880
00:48:23.597 : Distortion correction at px:-100.00 py:-100.00 zCoorection:10.812
00:48:23.597 : Distortion correction at px:-100.00 py:-50.00 zCoorection:10.887
00:48:23.597 : Distortion correction at px:-100.00 py:0.00 zCoorection:10.987
00:48:23.597 : Distortion correction at px:-100.00 py:50.00 zCoorection:11.125
00:48:23.597 : Distortion correction at px:-100.00 py:100.00 zCoorection:11.275
00:48:23.597 : Distortion correction at px:-50.00 py:-100.00 zCoorection:10.887
00:48:23.612 : Distortion correction at px:-50.00 py:-50.00 zCoorection:10.950
00:48:23.612 : Distortion correction at px:-50.00 py:0.00 zCoorection:10.975
00:48:23.612 : Distortion correction at px:-50.00 py:50.00 zCoorection:11.025
00:48:23.612 : Distortion correction at px:-50.00 py:100.00 zCoorection:11.150
00:48:23.612 : Distortion correction at px:0.00 py:-100.00 zCoorection:10.925
00:48:23.612 : Distortion correction at px:0.00 py:-50.00 zCoorection:10.975
00:48:23.628 : Distortion correction at px:0.00 py:0.00 zCoorection:10.950
00:48:23.628 : Distortion correction at px:0.00 py:50.00 zCoorection:11.012
00:48:23.628 : Distortion correction at px:0.00 py:100.00 zCoorection:11.012
00:48:23.628 : Distortion correction at px:50.00 py:-100.00 zCoorection:10.963
00:48:23.628 : Distortion correction at px:50.00 py:-50.00 zCoorection:10.925
00:48:23.628 : Distortion correction at px:50.00 py:0.00 zCoorection:10.913
00:48:23.628 : Distortion correction at px:50.00 py:50.00 zCoorection:10.925
00:48:23.643 : Distortion correction at px:50.00 py:100.00 zCoorection:10.937
00:48:23.643 : Distortion correction at px:100.00 py:-100.00 zCoorection:11.000
00:48:23.643 : Distortion correction at px:100.00 py:-50.00 zCoorection:10.950
00:48:23.643 : Distortion correction at px:100.00 py:0.00 zCoorection:10.887
00:48:23.659 : Distortion correction at px:100.00 py:50.00 zCoorection:10.788
00:48:23.660 : Distortion correction at px:100.00 py:100.00 zCoorection:10.775
00:48:23.665 : Z correction enabled
