HELP!!, Error:Apos y steps
edited January 2016 in Repetier-Firmware
Hello, Im trying to migrate from marlin, but after flashing I get the next error, "Error:Apos y steps"
the condition for that warning is:
  // A TOWER height
        uint32_t temp = RMath::absLong(Printer::deltaAPosYSteps - cartesianPosSteps[Y_AXIS]);
        uint32_t opt = Printer::deltaDiagonalStepsSquaredA.l;
        if (temp > LIMIT)
            RETURN_0("Apos y steps ");
One of the first tries I did I forgot to set my printer has a Delta, and went on configuring it has a Cartesian,
Does someone have any idea how to fix this?
  • Solve it, seems the EEPROM settings from marlin where the problem
  • edited January 2016
    I'm having the same problem with my printer only moving when doing babysteps. I have only had repetier on my board. When I try homing my printer it simply freezes up and wont respond from the screen or from repetier host.
    Full response before freezing.
    18:47:09.716 : Error:Apos y steps
    18:47:09.720 : Warning:Invalid delta coordinate - move ignored x:0 y:0 z:39600
    18:47:09.724 : Warning:in queueDeltaMove to calculateDeltaSubSegments returns error.
    18:47:09.724 : Warning:moveRelativeDistanceInSteps / queueDeltaMove returns error
  • Fixed it by resetting eeprom using the m502 command.
