How to apply end-stop corrections?
I have calibrated my bed level and I have offsets for the endstops, this is what one would usually adjust with the screws on thew carriages. I do not want to touch the screws so I would like to have these figures added in the code. How can I do that?
These are the numbers I have:
X-1.13 mm
Y -2.44 mm
Z 3.56 mm
Thanks!
// When you have several endstops in one circuit you need to disable it after homing by moving a
// small amount back. This is also the case with H-belt systems.
but only with positive numbers. Negative means you would trigger endstop end then continue that direction, which is forbidden. For deltas there is a offset for each endstop tower. There you would
#define ENDSTOP_Z_BACK_ON_HOME 10
plus your offsets.
