Extruder jamming on first print
Hello my extruder jammed on the first test print. Please see the video on Youtube.
There is a Kossel Mini.
https://youtu.be/67wMT6Zx2bo
Also some Pictures
https://onedrive.live.com/redir?resid=CD8F75CEDAF34F76!868&authkey=!AAHD6k3N3KY8nIY&ithint=folder%2cJPG
Does anybody have a clue of whats my problem?
Technical data for my Kossel Mini:
nozzle 0.4 mm
Repetier firmware
Repetier host
Slicer
Arduino and RAMPS 1.3
Best regards
Adam
  • Why do you post this in a "Repetier firmware" Forum? :) This seems not to be related to firmware issues and should be discussed in a more appropriate forum.
    You may google for hot end jams for instance. Typically those hotends are pretty cheap and might be improved by some rework (i.e. drilling through it, cleaning it, deburring). There are a lot of youtube videos on that topic.
  • Thank you for the tip. how do I delete this discussion?
    regards
    Adam
  • Its ok, nevermind. I dont think there is a delete function. :)
  • Jamming happens if your hot area gets too big. So lower temperature, improve cooling or google for common sultions fot that exact extruder. Each one has it's pros and cons.
