Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
Your printer requested a pause message
tss
January 2016
in
Repetier-Firmware
I get this message after homing when I keep hearing the motors from whatever reason, this happens about 60& of the time when I home the printer. What is the problem?
tss
January 2016
Some more details....
I'm using repetier firmware version 0.92.8.
Settings:
steps per mm = 100
max. travel speed = 200 mm/sec
homing speed = 80 mm/sec
travel acceleration = 1000 mm/sec^2
print acceleration = 1000 mm/sec^2
Repetier
January 2016
Delta printer? Than it is a problem with the endstops not fully untriggering for second attempt. Try going back a bit more so switches can turn off,
tss
January 2016
Yes, this is a delta printer. This means increasing "ENDSTOP_(X|Y|Z)_BACK_MOVE" ?
Repetier
January 2016
For delta only z is relevant, so
#define
ENDSTOP_Z_BACK_MOVE 3
would at least be a reason when not knowing your printer.
Sign In
or
Register
to comment.
#define ENDSTOP_Z_BACK_MOVE 3
