Y and z endstops OK X not triggered
I haven't found an answer to this one  yet.
I am using electronic endstops, they have an led light which goes off when they are triggered.
The Y and z endstops trigger perfectly on Min and Max. The X axis homes OK but tries to force its way past the endstop, the LED stays on.
The X,Y and Z endstops are all configured exactly the same, and if I load Marlin F/W it all works fine so I know it is not a board or mechanical issue.
It looks like the X axis endstops have not been enabled. Am I missing something?
This is my endstop config:
#define ENDSTOP_PULLUP_X_MIN false
#define ENDSTOP_PULLUP_Y_MIN false
#define ENDSTOP_PULLUP_X_MAX false
#define ENDSTOP_PULLUP_Y_MAX false
#define ENDSTOP_Y_MAX_INVERTING true
#define ENDSTOP_PULLUP_Z_MAX false
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
  • Test manually with M119 to see what gets triggered. Maybe xmin/max are swapped or direction is wrong since you have wrong motor direction compensated with wrong homing direction?
