Problem after Installation (delta Printer) (0.92)
I recently upgrade my chiness delta printer with a Ramp 1.4/Arduino mega 2560 /a988 stepper/Mechanical endstop
After many hours to config my endstop, i sucess to make the homing in the max position with no problem... but when im connect the printer to repetier host the printer remake is homing and after that the software say me the printer ask for a pause and when im click on continu the printer go down and dont stop ...... with the M119 command all my endstop is on L and when im push one is go H
im just out off idea ...... here my config .... for notice is not yet calibrated
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 4
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR -1
#define INVERT_Y_DIR -1
#define INVERT_Z_DIR -1
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 180
#define X_MIN_POS -1
#define Y_MIN_POS -1
#define Z_MIN_POS -1
// ## Movement settings ##
#define DELTA_SEGMENTS_PER_SECOND_MOVE 75 // Less accurate setting for other moves
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 180 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_MAX_RADIUS 125
#define ROD_RADIUS 85
#define PRINTER_RADIUS 85
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_FLOOR_SAFETY_MARGIN_MM 15
//#define SOFTWARE_LEVELING
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 250
#define MAX_FEEDRATE_Y 250
#define MAX_FEEDRATE_Z 250
#define HOMING_FEEDRATE_X 30
#define HOMING_FEEDRATE_Y 30
#define HOMING_FEEDRATE_Z 300
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 2
#define ALLOW_QUADSTEPPING 1
#define DOUBLE_STEP_DELAY 2 // time in microseconds
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 120
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 120
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 120
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 120
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 120
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 120
#define INTERPOLATE_ACCELERATION_WITH_Z 3
#define MAX_JERK 18
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define USE_ADVANCE 0
#define BAUDRATE 250000
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 0
