what variable do I change in the firmware so I can match x home pos in the eeprom
I have the following two variable in the eeprom config
X home pos -37.000 mm
Y home pos 12.000 mm
What variable do I need to change in the configuration file to set the variable. I have multiple printers so I prefer to upload the firmware when changes are made.
Thank you
  • Normally you can not define homing position. Only with homing order z preheat xy z you can set it. The coordinates are not stored in eeprom and only in config if I remember right. Config tool shows the options as soon as you select the homing order.
