[1.6.0] CuraEngine Inner Perimeter Speed Bug
Tested on Linux RepetierHost 1.6.0.
Settings under CuraEngine configuration that controls Inner Perimeter Speed do not apply on Slicing.
Investigation shows that field "insetXSpeed" in cura.ini is not updated with GUI stored value for Inner Perimeter Speed, but "infillSpeed" value.
Probably variable linking mistake.
As I understand CuraEngine logic:
inset0Speed - Outer Perimeter Speed
insetXSpeed - Inner Perimeter Speed
  • You are right. It was setting infill speed to inner perimeter. Fixed for next release. Thank you.
