SD card print
Hi, I have a problem with SD card printing.
If I start the SD card print directly on my printer, in the marlin firmware menu, it work very well. But, if I start the print via Repetier-host SD card print, it does nothing. My printer received a command because it display 0% on the lcd screen but it's stuck there. The printer doesn't move or heat.
Do you have an idea ?
  • Marlin has at some time made a change breaking sd operations with repetier.
    I have just checked the problem and found the solution. So with next 1.6.1 release it should work again.
  • Oh, thanks.
    I'm glad I found a bug :)
