RAMBo 1.1b thermistor pins 1 and 2 swapped?
Hi, I'm rebuilding a delta printer around a RAMBo 1.1b board, and I'm finding the temperature sensor pins aren't behaving right: T1 and T2 seem to be swapped around. Note that the T0 ADC on this board got fried by the previous owner, but otherwise the board seems fine. I'm therefore using the following physical pin layout:
T0: broken
T1: hot-end thermistor
T2: bed thermistor
T3: unused
I'm using Repetier Firmware 0.92, with Configuration.h initially generated by the online configurator, but modified by hand by me. The extruder and bed sensor pins are defined as follows:
#define EXT0_TEMPSENSOR_PIN TEMP_1_PIN
#define HEATED_BED_SENSOR_PIN TEMP_2_PIN
However, the temperature readings reported by the firmware are swapped around, and temperature control does not work. Looking around the source, I find that pins.h has the following for the RAMBo:
#define TEMP_0_PIN 0
#define TEMP_1_PIN 2
#define TEMP_2_PIN 1
#define TEMP_3_PIN 7
This seems to disagree with http://reprap.org/wiki/Rambo_development which has:
90 PF7 ( ADC7/PCINT15 ) Analog pin 7 Thermistor 3, Analog-Ext 5
91 PF6 ( ADC6/PCINT14 ) Analog pin 6 Analog-Ext 3
92 PF5 ( ADC5/TMS ) Analog pin 5 Analog-Ext 8
93 PF4 ( ADC4/TMK ) Analog pin 4 Analog-Ext 6
94 PF3 ( ADC3 ) Analog pin 3 Analog-Ext 4
95 PF2 ( ADC2 ) Analog pin 2 Thermistor 2
96 PF1 ( ADC1 ) Analog pin 1 Thermistor 1
97 PF0 ( ADC0 ) Analog pin 0 Thermistor 0
Similarly, the RAMBo 1.1b schematic has:
THERM0 A0
THERM1 A1
THERM2 A2
THERM3 A7
The current github version of Repetier Firmware's pins.h has:
I could be wrong, but it looks like TEMP_1_PIN and TEMP_2_PIN are incorrectly swapped in the firmware. Also, what happened to TEMP_3_PIN? I also noticed some rogue ^M characters in pins.h right where those pins are defined! Bad commit, maybe?
Thanks for any help you can offer,
screwtop
T0: broken
T2: bed thermistor
T3: unused
THERM0 A0
THERM1 A1
THERM2 A2
THERM3 A7
screwtop
