Filament runout detection ( when printer is blocking and communication buffer are full answers.....)
I load Marlin version 02010000 (BigTreeTech Octopus v 1.1) on my 3D printer which supports filament runout detection with a sensor attached to the printer motherboard. The sensor is a simple endstop switch, the problem is that whenever I start printing after some time a pop-up message comes {(filament run out) & ( Message from your printer ;; when printer is blocking and communication buffer are full answers might not to executed) (purge more) (disable runout)}
But it works perfect with normal screen
Better solution if supported in your marlin config is to switch to host handling for this useing M412
https://marlinfw.org/docs/gcode/M412.html
Add this e.g. in start print g-code of server
M412 H1 S1
could work here. But support must be compield into the firmware.
