MKS Gen L 2.1 Change out the net A8 converted to MKS and Repetier Firmware the EO Direction issue
edited July 2024 in Extruder & Bed
got an  ANet A8 the board has some blow component's and I had the MKS Gen L 2.1 laying around Used my Broadway file to setup
Works except for E0 Direction control is reversed.
overlooking the obvious would rather not remove and reset all the Pins on the Stepper motor for E0
Repetier host with configurator 1.0  Or 0.92 forgot which.
The direction of the manual control Normally the top arrow is out and the down arrow  IN, is to the heating element
Now the host control E0 down control is Out and so Up control is now the IN
The MKS gen L 2.1 pcb  the connector and JST plug are polarized.
Any chance of an  E0 invert direction in the Configurator or in the config H file?
figure simpler is better never had that issue before.
Recoush
  • Found it :>) in config H extruder 1 Inverse 0 changed to 1 Working :>)
