CNC Firmware
Hi!
I have a Shapeoko CNC machine. Are there any instructions on setting up Reptier-Firmware specifically for a CNC only machine? I have setup my 3D printer (my own Marlin deriviative) with RepFirm but as I wouldn't need most (any) of the 3D settings I am confused as to what I need to do to setup the firmware using the online tool.
Any help would be appreciated!
Which file format of vectric aspire accepts Repeater for CNC carve? I have tried Cam-Wood Postprocessor (txt), but appears some glitches. The glitch looks as too short bed in the direction X. It comes to the middle of the X axis and then goes to Y direction. It looks, that is bed length problem.
I have provided length as next
#define X_MAX_LENGTH 350
#define Y_MAX_LENGTH 700
But looks, that it see only 200mm on X direction. Maybe there is additional function for bed leveling?
Same file works perfect with Grbl Controller
Solved! I have found a length configuration at firmware configurations ALT+E. ))
Thank you!
