Heat creep ?
After 10 years of good service, I encountered the problem with filament clogging the teflon tube near heat-break area.
Because all worked more/less without problems for a long time, I am puzzled this problem surfaced now.. obviously some setting was too close to wrong value and possibly change of the environmental temperature tipped the scale in wrong direction..
Printer is DIY, with MK-8 print head (one extruder), and I am using ABS (bed 100°C, hot end at 240°C).
Is there some setting in EEPROM that can help mitigating this problem?
Thank you in advance for any reply/suggestion!
Bojan
Actually, the most puzzling thing was, after trying this and that, it worked OK for couple of hours, and I thought the problem wassolved, but it was back the next day when I continued (without changing anything in settings !)
Waht I forgot is it can also be that your tubing has moved a bit in the Extruder. Not sure about the details but when there starts a gap near heatbreak movement gets harder and can require more force. Also check if extruder gear has too much debris preventing best grip so it starts to not have enough force.
