Issues compiling firmware
Hi guys,
I recently bought a 3d printer and it hasn't been working correctly. So the seller instructed me to update the firmware. They didn't really give any instructions and i've been struggling with some errors while compiling the firmware.
Here they are:
Here they are:
Arduino: 1.6.5 (Windows 7), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\ui.h:1150:0: warning: "BEEPER_LONG_SEQUENCE" redefined [enabled by default]
#define BEEPER_LONG_SEQUENCE 24,8
In file included from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Repetier.h:179:0,
from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Drivers.cpp:1:
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Configuration.h:423:0: note: this is the location of the previous definition
In file included from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Repetier.h:441:0,
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\ui.h:1796:8: warning: extra tokens at end of #endif directive [enabled by default]
#endif CONTROLLER_LCD_MP_PHARAOH_DUE
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\ui.h:290:16: warning: 'UIMenu_struct' has a field 'UIMenu_struct::entries' whose type uses the anonymous namespace [enabled by default]
typedef struct UIMenu_struct {
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\ui.h:1887:13: warning: unused parameter 'action' [-Wunused-parameter]
static void ui_check_Ukeys(int &action) {
In file included from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Repetier.h:775:0,
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\motion.h:449:17: warning: unused parameter 'v' [-Wunused-parameter]
inline void updateAdvanceSteps(speed_t v, uint8_t max_loops, bool accelerate)
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\motion.h:449:17: warning: unused parameter 'max_loops' [-Wunused-parameter]
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\motion.h:449:17: warning: unused parameter 'accelerate' [-Wunused-parameter]
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\ui.h:1887:13: warning: 'void ui_check_Ukeys(int&)' defined but not used [-Wunused-function]
C:\Users\asus\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\hardware\tools\avr/bin/avr-g++ -c -g -Os -Wall -Wextra -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\asus\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\hardware\arduino\avr\cores\arduino -IC:\Users\asus\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\hardware\arduino\avr\variants\mega -IC:\Users\asus\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\hardware\arduino\avr\libraries\SPI C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Eeprom.cpp -o C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Eeprom.cpp.o
In file included from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Configuration.h:41:0,
from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Repetier.h:179,
from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Eeprom.cpp:24:
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\pins.h:2404:58: warning: "/*" within comment [-Wcomment]
#define TEMP_0_PIN 14 // ANALOG NUMBERING ////***Extuder1
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\pins.h:2405:58: warning: "/*" within comment [-Wcomment]
#define TEMP_1_PIN 15 // ANALOG NUMBERING ////***Bed
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\pins.h:2406:58: warning: "/*" within comment [-Wcomment]
#define TEMP_2_PIN 13 // ANALOG NUMBERING ////***Extuder2
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\pins.h:2408:58: warning: "/*" within comment [-Wcomment]
#define TEMP_3_PIN 12 // ANALOG NUMBERING ////***Extuder3
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Configuration.h:46:0: warning: "FAN_BOARD_PIN" redefined [enabled by default]
#define FAN_BOARD_PIN ORIG_FAN2_PIN
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\pins.h:2513:0: note: this is the location of the previous definition
#define FAN_BOARD_PIN -1
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\ui.h:192:0: warning: "UI_ACTION_EXTRUDER2_TEMP" redefined [enabled by default]
#define UI_ACTION_EXTRUDER2_TEMP 1124
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\ui.h:172:0: note: this is the location of the previous definition
#define UI_ACTION_EXTRUDER2_TEMP 1103
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\ui.h:1149:0: warning: "BEEPER_SHORT_SEQUENCE" redefined [enabled by default]
#define BEEPER_SHORT_SEQUENCE 6,2 // Needs longer beep sequence
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Configuration.h:422:0: note: this is the location of the previous definition
C:\Users\asus\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\hardware\tools\avr/bin/avr-g++ -c -g -Os -Wall -Wextra -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR -IC:\Users\asus\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\hardware\arduino\avr\cores\arduino -IC:\Users\asus\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\hardware\arduino\avr\variants\mega -IC:\Users\asus\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\hardware\arduino\avr\libraries\SPI C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Extruder.cpp -o C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Extruder.cpp.o
from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Extruder.cpp:22:
from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\HAL.cpp:1:
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\HAL.cpp: In static member function 'static void HAL::analogStart()':
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\HAL.cpp:323:10: warning: variable 'dummyADCResult' set but not used [-Wunused-but-set-variable]
uint dummyADCResult;
In file included from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\HAL.h:83:0,
from C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\Repetier.h:434,
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\HAL.cpp: In function 'void __vector_22()':
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\fastio.h:29:39: error: 'DIOORIG_FAN2_PIN_WPORT' was not declared in this scope
#define _WRITE(IO, v) do { if (v) {DIO ## IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ## IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\fastio.h:48:25: note: in expansion of macro '_WRITE'
#define WRITE(IO, v) _WRITE(IO, v)
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\HAL.cpp:847:97: note: in expansion of macro 'WRITE'
if((pwm_pos_set[NUM_EXTRUDER + 1] = (pwm_pos[NUM_EXTRUDER + 1] & COOLER_PWM_MASK)) > 0) WRITE(FAN_BOARD_PIN,1);
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\fastio.h:29:68: error: 'DIOORIG_FAN2_PIN_PIN' was not declared in this scope
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\fastio.h:17:30: note: in definition of macro 'MASK'
#define MASK(PIN) (1 << PIN)
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\fastio.h:29:96: error: 'DIOORIG_FAN2_PIN_WPORT' was not declared in this scope
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\fastio.h:29:126: error: 'DIOORIG_FAN2_PIN_PIN' was not declared in this scope
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\HAL.cpp:941:111: note: in expansion of macro 'WRITE'
if(pwm_pos_set[NUM_EXTRUDER + 1] == pwm_count_cooler && pwm_pos_set[NUM_EXTRUDER + 1] != COOLER_PWM_MASK) WRITE(FAN_BOARD_PIN,0);
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\HAL.cpp:789:20: warning: unused variable 'pwm_cooler_pos_set' [-Wunused-variable]
static uint8_t pwm_cooler_pos_set[NUM_EXTRUDER];
C:\Users\asus\AppData\Local\Temp\build3182262124253766657.tmp\ui.h: At global scope:
Error compiling.
Any idea what it could be?
