Z motor stepper moves once only
Printer Prusa i3, board Melzi, firmware repetier 0.92.4. Manual control with repetier-host, X and Y move ok, Z moves just a little, only once. I have to shut down completely (USB and power supply), restart and then same behaviour.
Any advice ? Thanks.
Regards,
P.Linden
Regards,
P.Linden
After checking above points, i did'nt find the fault. I tried to modify various parameters, but no success.
Please find EEPROM content here after :
<?xml version="1.0" encoding="utf-8"?><Repetier-Firmware-EEPROM><epr pos="1028" type="0" value="255">Language</epr><epr pos="75" type="2" value="115200">Baudrate</epr><epr pos="129" type="3" value="0.000">Filament printed</epr><epr pos="125" type="2" value="0">Printer active</epr><epr pos="79" type="2" value="0">Max. inactive time</epr><epr pos="83" type="2" value="360000">Stop stepper after inactivity</epr><epr pos="3" type="3" value="80.0000">X-axis steps per mm</epr><epr pos="7" type="3" value="80.0000">Y-axis steps per mm</epr><epr pos="11" type="3" value="2560.0000">Z-axis steps per mm</epr><epr pos="15" type="3" value="200.000">X-axis max. feedrate</epr><epr pos="19" type="3" value="200.000">Y-axis max. feedrate</epr><epr pos="23" type="3" value="2.000">Z-axis max. feedrate</epr><epr pos="27" type="3" value="40.000">X-axis homing feedrate</epr><epr pos="31" type="3" value="40.000">Y-axis homing feedrate</epr><epr pos="35" type="3" value="2.000">Z-axis homing feedrate</epr><epr pos="39" type="3" value="20.000">Max. jerk</epr><epr pos="47" type="3" value="0.300">Max. Z-jerk</epr><epr pos="133" type="3" value="0.000">X min pos</epr><epr pos="137" type="3" value="0.000">Y min pos</epr><epr pos="141" type="3" value="0.000">Z min pos</epr><epr pos="145" type="3" value="200.000">X max length</epr><epr pos="149" type="3" value="200.000">Y max length</epr><epr pos="153" type="3" value="120.000">Z max length</epr><epr pos="51" type="3" value="1000.000">X-axis acceleration</epr><epr pos="55" type="3" value="1000.000">Y-axis acceleration</epr><epr pos="59" type="3" value="100.000">Z-axis acceleration</epr><epr pos="63" type="3" value="1000.000">X-axis travel acceleration</epr><epr pos="67" type="3" value="1000.000">Y-axis travel acceleration</epr><epr pos="71" type="3" value="50.000">Z-axis travel acceleration</epr><epr pos="1024" type="3" value="0.000">Coating thickness</epr><epr pos="880" type="0" value="0">Autolevel active (1/0)</epr><epr pos="106" type="0" value="0">Bed Heat Manager</epr><epr pos="107" type="0" value="255">Bed PID drive max</epr><epr pos="124" type="0" value="80">Bed PID drive min</epr><epr pos="108" type="3" value="196.000">Bed PID P-gain</epr><epr pos="112" type="3" value="33.000">Bed PID I-gain</epr><epr pos="116" type="3" value="290.000">Bed PID D-gain</epr><epr pos="120" type="0" value="255">Bed PID max value</epr><epr pos="1020" type="0" value="0">Enable retraction conversion</epr><epr pos="992" type="3" value="3.000">Retraction length</epr><epr pos="1000" type="3" value="40.000">Retraction speed</epr><epr pos="1004" type="3" value="0.000">Retraction z-lift</epr><epr pos="1008" type="3" value="0.000">Extra extrusion on undo retract</epr><epr pos="1016" type="3" value="20.000">Retraction undo speed</epr><epr pos="200" type="3" value="95.000">Extr.1 steps per mm</epr><epr pos="204" type="3" value="50.000">Extr.1 max. feedrate</epr><epr pos="208" type="3" value="20.000">Extr.1 start feedrate</epr><epr pos="212" type="3" value="100.000">Extr.1 acceleration</epr><epr pos="216" type="0" value="3">Extr.1 heat manager</epr><epr pos="217" type="0" value="230">Extr.1 PID drive max</epr><epr pos="245" type="0" value="40">Extr.1 PID drive min</epr><epr pos="218" type="3" value="7.0000">Extr.1 PID P-gain/dead-time</epr><epr pos="222" type="3" value="2.0000">Extr.1 PID I-gain</epr><epr pos="226" type="3" value="40.0000">Extr.1 PID D-gain</epr><epr pos="230" type="0" value="255">Extr.1 PID max value</epr><epr pos="231" type="2" value="0">Extr.1 X-offset</epr><epr pos="235" type="2" value="0">Extr.1 Y-offset</epr><epr pos="290" type="2" value="0">Extr.1 Z-offset</epr><epr pos="239" type="1" value="1">Extr.1 temp. stabilize time</epr><epr pos="250" type="1" value="150">Extr.1 temp. for retraction when heating</epr><epr pos="252" type="1" value="0">Extr.1 distance to retract when heating</epr><epr pos="254" type="0" value="255">Extr.1 extruder cooler speed</epr></Repetier-Firmware-EEPROM>
For information, when z motors stop, the board still reacts ( echo of the commands) but no Z move. I must switch off the power and remove the USB cable, reset button does not react. After switchING power on and connecting the USB, i can try the z-move and i obtain this very short move (impulse) and nothing after that. Is it a security in the driver itself ( A4982)?
Regards,
Paul LINDEN
I'm really unable to imagine a solution ! Please HELP !
Thanks in advance for any hint !
Paul LINDEN
What type of control board you are using?
Also what is your firmware and how you develop it?
Can you please post the specifications of all your hardware including motors also?
Just for fun, I just plugged Z connector on the X output of the board and the X connector on the Z out put.
Using manual control of Repetier-host : clic on X move : Z moves , that's logic, but clicking on Z moves Z also !
Any idea ?????
For ElmaWebber : all details see the beginning of this thread !
Serial speed controlled : 115200.
Any advice ?
with my Olimex AVRISP-MK2 and using Atmel Studio, i can read, verify and upload the firmware as an .hex file and also read, verify and upload the eeprom content as an .eep file. The files i used are copy of the original Melzi board. You explained that i have to change the eeprom mode. This is what i do when compiling a new version of the firmware. But when uploading to the eeprom with my ISP, is it necessary to change the mode and how can i do this ?
- using the display i just checked the baud rate, it's ok 115200
- using local commands (buttons near the display) i checked some eeprom values like accelerations, feedrate,steps per mm and so on. All values conform to the original eeprom.
- Using local buttons for moves: X moves brutally, values greater than awaited. Y moves also with strange values. Z rotates a little bit in random directions.
- I explored the FTDI issue as explained on "http://reprap.org/wiki/Melzi#Can.27t_connect_to_the_Melzi_.28FTDI_driver_problem.29" and the PID is effectivly 0000 instead of 6001 !!! This means that i have a counterfeited FTDI chip ! I suppose this explain strange behaviour of the board.
Do you know a method how to restore the correct PID ? Thanks !!
Im having same thing Ive used the default setting command for printer but I was at 25000 baudrate, when I saved it lost connection and wouldnt connect.
I checked lcd for baudrate which had changed to 11520 so I changed repetier host and connected fine.
I can move extruder with the lcd position and move E to 1mm it will start spinning like mad and not stop. I then press again and it does like 1mm movements then dies, cant control threw repetier host.
With Z straight after a start up if I use manual control it will move, some times do same as Z, also had Y do it with manual control homing individual axes in XY and Z order.
I can get Z to turn slightly in each direction and E to move with lcd.
Tbh just changed Z steps per mm to 3200 and it is tighter but still not working.
Ive done literally everything and stressed now.
Is all of my experience so far im ready to give up again as this the 3rd time in 3 months ive dedicated many days to get no results.
Why put a programme on a machine if it dont work.
