Confirm tool change with Repetier Host
I am Using SKR Pro 1.2 with Marlin on a MPCNC, controlled by Repetier Host. Code is generated either by Fusion 360 or Estlcam.
When it comes to a tool change, CNC stops. After I change the Tools, i see no possibility to continue to run CNC. Workaround so far to seperate the gcode into several parts an run them one after the other. Is there any solution to select "continue" on my PC with Repetier Host?
In repeiter-host you would insert
@pause
to add a pause that is controlled by host. Other solutions might need interaction on printer lcd instead.
Should it look like this?
Thanks a lot for your help in this matter
Unfortunately I do not have a display.
Without an LCD controller or
EMERGENCY_PARSER
this command is ignored.With
EMERGENCY_PARSER
enabled theM108
command can be used to continue.So you can try sending M108 but not sure how emergency support is in host. I know I added it for Repetier-Server but @pause is in both cases the better solution here.
