new from 2015 Zim from Zeepro fillement feed motors aren't turning Is it hardware or software?
old printer won't feed fillement ? It goes through entire print process but the feed stepper motors never turn.. It's a Zeepro Zim cartrige fed printer from 2015-ish ?
  • Any error messages in communication console? Make sure extruder is hot. Eventually motor driver or motor cable defect if it worked before.
  • there are no screen(s) attached to this printer nor SD slot. this model was supported by it's own website via USB and camera was supported by wi-fi so, No code(s)
  • Sure it is using Repetier-Firmware? We never supported wifi/camera in that firmware. What does M115 show as firmware?
