Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
temistör nor workiing
ozgehanaytkn
January 2024
in
Repetier-Firmware
max 6675 _This thermistor is not working properly. I changed the line named temp0, it was 1, I changed it to 101, it didn't work, I'm using ramps 1.3..
Repetier
January 2024
Do you also have
#define
SUPPORT_MAX6675
in your configuration.h file to enable 6675 support. Pin is the cs pin for spi connection to the max6675.
Sign In
or
Register
to comment.
