How to force webserver to redirect only to https?
Hi there,
I have RS running on a Raspberry Pi 3b
My organization requires that internal webservers resolve only in https. I've configured the server as described on the website, but it's still broadcasting http on port 3344.
I was able to block port 3344, but it had the side effect of blocking the webcams, too.
I'm not much of a linux network security guy, which is why I'm writing this post. Can you point me in the right direction?
thanks in advance
thanks in advance
http is always enabled as fallback in case certificates are not trusted/expired. So blocking that port is the way to go. Please note that server has now a own https solution you can enable as well in addition to forwarding to it.
