32 bit
Want to use a different controller card. Now I use a 8 bit card . Mks gen l... (ramps clone) want to try 32 bit card. Must work with Repetier firmware. Any suggestions ?
Very satisfied with the Repetier FW
  • The V1 version does only support due based 32 bit boards which are not up to date any more. Now they normally use ST 32 bit controller. Some of them are supported by our V2 firmware which is a complete rewrite without config tool but good documentation. But be aware that there will be only few updates for it - we mostly stopped development apart from some bug fixes. So check the board is listen in the supported list for V2 and also check if you think you can program the printer with the new macro system. There are some samples so you get an indea how to do it.
