M323 unkown command and more autolevel mysteries
im getting more into the autolevel procedure and I managed to get a heightmap, a G32, G30 and G29. However I cant get them to be applied.
first the height map seems to give out relalistic values with no correction applied. and G32 S2 produces a realistic looking transformation matrix. (values between 0 and 1) the new printer height is also stored correctly in EEPROM
the video then tells me to do a G29 to get a 7x7 distortion matrix but what the printer does is different. it performs a 3 point probe and no correction is applied, because when I repeat the heightmap it still shows an uncorrected map. furthermore when I type M323 to check the correction I get an "unknown command"
Im not sure how to combat this. It cant even tell is the transformation matrix from the G32 is applied and what the difference is to the distortion matrix from the G29/M323: I guess the routine changed quite a bit since the video and to guide were produced? Any chance there is updated documentation out there?
