Resetting EEPROM information
So I began using Repetier host on my computer with my first printer, a Prusa Mendel I3. I have since sold that printer and am using a Kossel Mini variant.
While I created a new configuration for the printer in the printer settings, and the EEPROM configuration in the host is different from the I3's, there seems to be confusion somewhere in the firmware and/or host.
The printer does not seem to act on the Repetier Host's EEPROM configuration, because z probing (to auto level the bed) is set at 1, however, when saving to the EEPROM using manual gcode, z probing is set at 0, and when I attempt to use G32 to begin the probing process, I get a response that it is disabled. z probing is enabled in the configuration.h as well.
I'm not entirely sure what settings the printer is acting on, so when I get the chance, I am going to use the M502 code to reset the printer's EEPROM. What else should I do in the repetier host to ensure that it is up to date with the printer? Will I need to uninstall and reinstall? If so, are there any special folders to remove, or will it be removed with the uninstall?
