Repetier Manual command acting weird
Hello All,
Whenever I use the home button in Manual command, if the homing axis along with Z-axis will move. Example: if I try to home X-axis using the home button, Z-axis will to 5 unit (only if it lower than 5 units) and only then X-axis will home. The echo would be:
G28 X0*111
Based on the echo, it's not giving any command to move Z axis.
G28 X0*111
