Is there a way to see the revision history even when there is no newer version available? I can't seem to find it. If not this would be a nice addition.
I was actually asking if there was a way from inside RH. I like how it displays when there is a newer version available. I was wondering if there was a way to bring up this screen at any time.
Check update shows if a update is available and then you get the same list, maybe a bit truncated at the end. Once installed you can not see it any more.
Yes but you can only review the release notes if there is a new version available. Once you've upgraded to the latest version all the check update option says is, "No new updates available" with no option anymore to see the release notes. What I'd like to see is a way to always get to the release notes list from inside the app regardless of what version you are using.
Rob
As always, thanks for great software!
Rob
