Auto Bed leveling 3D BL Touch
I have installed a 3D Touch on my printer and I would like to level the platen using Repetier Host.
All the G-codes I have used to launch this plate levelling have so far not worked. I have seen in my research that I need to enable FEATURE_Z_PROBE for this to work. Is there a code to enable this variable from Repetier-Host? If not, how can I activate this variable on my printer?
But you need to configure the firmware to have support for it compiled in as well as controlling the servo fo the bltouch to deploy the probe and retract it. In this forum you will find several threads describing this. The host software has nothing to do regardless which, autoleveling is done completely in firmware. Only when compiled you can change some parameter for leveling/probing in the eeprom settings.
You can also try googling for it. Maybe someone has one for it made public as a quick starting point.
