Could this calibration tool be used with Repetier firware?
Hello, folks!
We have got a nice LA calibration tool which is much more visual than the Marlin calibrator.
https://k3d.tech/calibrations/la/pics/la5.png
Instructions could be found here
https://k3d.tech/calibrations/la/ and calibrator itself here https://k3d.tech/calibrations/la/k3d_la.html
Sorry but it is available only in russian. But google can translate the page for you if you don't mind.
As result it produces the K-factor ranging from 0.01 to 0.1 or whatever range we set for testing. Is it compatibel with Repetier firmware?
May be we can generate the calibration G-code and replace M900 K with M233 Y BEFORE running the calibraton?
Thank you!
  • Yes, you can do that. I've done that in past with marlin calibrator as well. Just check the range of values generated to match what you need for Repetier firmware. I rember values of 40 for direct printers.
