changing speeds between lines and curves
Hello everyone,
At my university we build our own delta printer for ceramics. It is running Repetier firmware and this is working great except for one bug I cannot solve. When printing straight lines, the printer reduces the movement and extrusion speed drastically. For curves and arcs it moves much faster.
I've tried searching for solutions on this and other forums but haven't found an answer.
Any tips on how to solve this or where to look for an answer would be great!
Here is a video where you can see the extruder and movement speed slowing down as soon as it hits a straight part:
https://drive.google.com/file/d/1kwYADXAI-q08KuF8l2EROEA9ohVdbZ4m/view?usp=sharingAny tips on how to solve this or where to look for an answer would be great!
This is the configuration.h :
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
This file is optimized for version 1.0.4dev
as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 33
#include "pins.h"
#define HOST_RESCUE 1
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
#define FAN_THERMO_MAX_PWM 0
#define FAN_THERMO_MIN_TEMP 0
#define FAN_THERMO_MAX_TEMP 0
#define FAN_THERMO_THERMISTOR_TYPE 0
#undef X_MIN_PIN
#define X_MIN_PIN -1
#undef Y_MIN_PIN
#define Y_MIN_PIN -1
#undef Z_MIN_PIN
#define Z_MIN_PIN -1
#undef X_MAX_PIN
#define X_MAX_PIN ORIG_Z_MAX_PIN
#undef Z_MAX_PIN
#define Z_MAX_PIN ORIG_X_MAX_PIN
#undef X_STEP_PIN
#define X_STEP_PIN ORIG_Z_STEP_PIN
#undef X_DIR_PIN
#define X_DIR_PIN ORIG_Z_DIR_PIN
#undef X_ENABLE_PIN
#define X_ENABLE_PIN ORIG_Z_ENABLE_PIN
#undef Z_STEP_PIN
#define Z_STEP_PIN ORIG_X_STEP_PIN
#undef Z_DIR_PIN
#define Z_DIR_PIN ORIG_X_DIR_PIN
#undef Z_ENABLE_PIN
#define Z_ENABLE_PIN ORIG_X_ENABLE_PIN
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 3
#define SAFE_HOMING 1
#define XAXIS_STEPS_PER_MM 80
#define YAXIS_STEPS_PER_MM 80
#define ZAXIS_STEPS_PER_MM 80
#define EXTRUDER_FAN_COOL_TEMP 0
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define DECOUPLING_TEST_MIN_TEMP_RISE_BED 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 400
#define EXT0_TEMPSENSOR_TYPE 0
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 3
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 0
#define PID_CONTROL_RANGE_BED 10
#define SKIP_M109_IF_WITHIN 0
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define TEMP_GAIN 0
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 0
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 0
#define MAXTEMP 0
#define MIN_DEFECT_TEMPERATURE 0
#define MAX_DEFECT_TEMPERATURE 0
#define MILLISECONDS_PREHEAT_TIME 0
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 2
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 0
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
#define Z_MAX_LENGTH 951.5
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 0
#define PARK_POSITION_Z_RAISE 30
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_DIAGONAL_ROD 466.2 // mm
#define DELTA_ALPHA_A 210
#define DELTA_ALPHA_B 330
#define DELTA_ALPHA_C 90
#define DELTA_MAX_RADIUS 210
#define ROD_RADIUS 250.61
#define PRINTER_RADIUS 250.61
#define DELTA_HOME_ON_POWER 0
#define STEP_COUNTER
#define DELTA_FLOOR_SAFETY_MARGIN_MM 15
//#define SOFTWARE_LEVELING
#define STEPPER_INACTIVE_TIME 3600L
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 100
#define HOMING_FEEDRATE_X 20
#define HOMING_FEEDRATE_Y 20
#define HOMING_FEEDRATE_Z 20
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 0
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 2
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define MAX_FAN_PWM 255
#define FEATURE_WATCHDOG 0
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 0
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_IIS2DH 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 40
#define Z_PROBE_DELAY 0
#define FEATURE_AUTOLEVEL 0
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 20
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#define SD_RUN_ON_STOP ""
#define SD_STOP_HEATER_AND_MOTORS_ON_STOP 0
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 2
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define LANGUAGE_RU_ACTIVE 0
#define UI_PRINTER_NAME "C3D V3"
#define UI_PRINTER_COMPANY "dpz"
#define UI_DISABLE_AUTO_PAGESWITCH 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 3
#define UI_KEY_FIRST_REPEAT 750
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_DYNAMIC_ENCODER_SPEED 0
#define UI_SET_MIN_HEATED_BED_TEMP 0
#define UI_SET_MIN_EXTRUDER_TEMP 0
#define NUM_MOTOR_DRIVERS 0
"editMode": 1,
"processor": 0,
"baudrate": 115200,
"safeHoming": "1",
"bluetoothSerial": -1,
"bluetoothBaudrate": 115200,
"xStepsPerMM": 80,
"yStepsPerMM": 80,
"zStepsPerMM": 80,
"xInvert": "0",
"x2Invert": 0,
"xInvertEnable": 0,
"eepromMode": 2,
"yInvert": "0",
"y2Invert": 0,
"yInvertEnable": 0,
"zInvert": 0,
"z2Invert": 0,
"z3Invert": 0,
"z4Invert": 0,
"zInvertEnable": 0,
"extruder": [
"id": 0,
"heatManager": 3,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 0,
"sensorPin": "TEMP_0_PIN",
"heaterPin": "HEATER_0_PIN",
"maxFeedrate": 50,
"startFeedrate": 20,
"invert": "0",
"invertEnable": "0",
"acceleration": 5000,
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetractTemp": 150,
"waitRetractUnits": 0,
"waitRetract": 0,
"stepsPerMM": 400,
"coolerPin": -1,
"coolerSpeed": 255,
"selectCommands": "",
"deselectCommands": "",
"xOffset": 0,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"name": "Extruder 0",
"step": "ORIG_E0_STEP_PIN",
"dir": "ORIG_E0_DIR_PIN",
"advanceBacklashSteps": 0,
"decoupleTestPeriod": 12,
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"preheat": 190
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 0,
"yMinEndstop": 0,
"zMinEndstop": 0,
"xMaxEndstop": 2,
"yMaxEndstop": 2,
"zMaxEndstop": 2,
"x2MinEndstop": 0,
"y2MinEndstop": 0,
"x2MaxEndstop": 0,
"y2MaxEndstop": 0,
"motherboard": 33,
"driveSystem": 3,
"xMaxSpeed": 200,
"xHomingSpeed": 20,
"xTravelAcceleration": 100,
"xPrintAcceleration": 1000,
"yMaxSpeed": 200,
"yHomingSpeed": 20,
"yTravelAcceleration": 100,
"yPrintAcceleration": 1000,
"zMaxSpeed": 100,
"zHomingSpeed": 20,
"zTravelAcceleration": 100,
"zPrintAcceleration": 100,
"xMotor": {
"name": "Z motor",
"step": "ORIG_Z_STEP_PIN",
"dir": "ORIG_Z_DIR_PIN",
"enable": "ORIG_Z_ENABLE_PIN"
"yMotor": {
"name": "Y motor",
"step": "ORIG_Y_STEP_PIN",
"dir": "ORIG_Y_DIR_PIN",
"enable": "ORIG_Y_ENABLE_PIN"
"zMotor": {
"name": "X motor",
"step": "ORIG_X_STEP_PIN",
"dir": "ORIG_X_DIR_PIN",
"enable": "ORIG_X_ENABLE_PIN"
"enableBacklash": "0",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"stepperInactiveTime": 3600,
"maxInactiveTime": 0,
"xMinPos": 0,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 200,
"yLength": 200,
"zLength": 951.5,
"alwaysCheckEndstops": "1",
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "0",
"xHomeDir": "-1",
"yHomeDir": "-1",
"zHomeDir": 1,
"xEndstopBack": 1,
"yEndstopBack": 1,
"zEndstopBack": 0,
"deltaDiagonalRod": 466.2,
"deltaHorizontalRadius": 250.61,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"deltaDiagonalCorrA": 0,
"deltaDiagonalCorrB": 0,
"deltaDiagonalCorrC": 0,
"deltaMaxRadius": 210,
"deltaRadiusCorrA": 0,
"deltaRadiusCorrB": 0,
"deltaRadiusCorrC": 0,
"deltaXOffsetSteps": 0,
"deltaYOffsetSteps": 0,
"deltaZOffsetSteps": 0,
"deltaSegmentsPerLine": 20,
"stepperHighDelay": 0,
"directionDelay": 0,
"allowQuadstepping": "1",
"doubleStepDelay": 0,
"maxJerk": 20,
"maxZJerk": 0.3,
"moveCacheSize": 16,
"moveCacheLow": 10,
"lowTicksPerMove": 250000,
"enablePowerOnStartup": "1",
"echoOnExecute": "1",
"sendWaits": "1",
"ackWithLineNumber": "1",
"killMethod": 1,
"useAdvance": "0",
"useQuadraticAdvance": "0",
"powerInverting": 0,
"mirrorX": 0,
"mirrorXMotor": {
"name": "Extruder 1",
"step": "ORIG_E1_STEP_PIN",
"dir": "ORIG_E1_DIR_PIN",
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": "0",
"mirrorZMotor": {
"mirrorZ3": "0",
"mirrorZ3Motor": {
"name": "Extruder 2",
"step": "ORIG_E2_STEP_PIN",
"dir": "ORIG_E2_DIR_PIN",
"mirrorZ4": "0",
"mirrorZ4Motor": {
"name": "Extruder 3",
"step": "ORIG_E3_STEP_PIN",
"dir": "ORIG_E3_DIR_PIN",
"dittoPrinting": "0",
"featureServos": "0",
"servo0Pin": 11,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"featureWatchdog": "0",
"hasHeatedBed": "0",
"enableZProbing": "0",
"extrudeMaxLength": 160,
"featureController": 2,
"uiPrinterName": "C3D V3",
"uiPrinterCompany": "dpz",
"uiPagesDuration": 4000,
"uiHeadline": "",
"uiDisablePageswitch": "0",
"uiAutoReturnAfter": 30000,
"featureKeys": "0",
"uiEncoderSpeed": 1,
"uiReverseEncoder": "0",
"uiKeyBouncetime": 3,
"uiKeyFirstRepeat": 750,
"uiKeyReduceRepeat": 50,
"uiKeyMinRepeat": 50,
"featureBeeper": "0",
"uiMinHeatedBed": 0,
"uiMaxHeatedBed": 120,
"uiMinEtxruderTemp": 0,
"uiMaxExtruderTemp": 260,
"uiExtruderFeedrate": 2,
"maxBedTemperature": 120,
"bedSensorType": 1,
"bedSensorPin": "TEMP_1_PIN",
"bedHeatManager": 0,
"bedPreheat": 55,
"bedUpdateInterval": 5000,
"bedPidDriveMin": 80,
"bedPidDriveMax": 255,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"bedDecoupleTestPeriod": 300,
"caseLightPin": -1,
"caseLightDefaultOn": "1",
"bedSkipIfWithin": 3,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"tempHysteresis": 0,
"pidControlRange": 0,
"pidControlRangeBed": 10,
"skipM109Within": 0,
"extruderFanCoolTemp": 0,
"minTemp": 0,
"maxTemp": 0,
"minDefectTemp": 0,
"maxDefectTemp": 0,
"arcSupport": "1",
"forceChecksum": "0",
"sdExtendedDir": "1",
"featureFanControl": "1",
"fanPin": "ORIG_FAN_PIN",
"featureFan2Control": "0",
"fan2Pin": "ORIG_FAN2_PIN",
"fanThermoPin": -1,
"fanThermoMinPWM": 128,
"fanThermoMaxPWM": 0,
"fanThermoMinTemp": 0,
"fanThermoMaxTemp": 0,
"fanThermoThermistorPin": -1,
"fanThermoThermistorType": 0,
"scalePidToMax": 0,
"zProbePin": -1,
"zProbeIIS2DH": "0",
"zProbeBedDistance": 10,
"zProbeDisableHeaters": "0",
"zProbePullup": "0",
"zProbeOnHigh": "0",
"zProbeXOffset": 0,
"zProbeYOffset": 0,
"zProbeWaitBeforeTest": "0",
"zProbeSpeed": 2,
"zProbeXYSpeed": 150,
"zProbeHeight": 40,
"zProbeStartScript": "",
"zProbeFinishedScript": "",
"featureAutolevel": "0",
"zProbeX1": 20,
"zProbeY1": 20,
"zProbeX2": 160,
"zProbeY2": 20,
"zProbeX3": 20,
"zProbeY3": 160,
"zProbeSwitchingDistance": 1,
"zProbeRepetitions": 1,
"zProbeMedian": "0",
"zProbeEveryPoint": "",
"sdSupport": "1",
"sdCardDetectPin": -1,
"sdCardDetectInverted": "0",
"uiStartScreenDelay": 1000,
"xEndstopBackMove": 5,
"yEndstopBackMove": 5,
"zEndstopBackMove": 2,
"xEndstopRetestFactor": 3,
"yEndstopRetestFactor": 3,
"zEndstopRetestFactor": 3,
"xMinPin": -1,
"yMinPin": -1,
"zMinPin": -1,
"xMaxPin": "ORIG_Z_MAX_PIN",
"yMaxPin": "ORIG_Y_MAX_PIN",
"zMaxPin": "ORIG_X_MAX_PIN",
"x2MinPin": -1,
"y2MinPin": -1,
"x2MaxPin": -1,
"y2MaxPin": -1,
"deltaHomeOnPower": "0",
"fanBoardPin": -1,
"heaterPWMSpeed": 0,
"featureBabystepping": "1",
"babystepMultiplicator": 1,
"pdmForHeater": "0",
"pdmForCooler": "0",
"psOn": -1,
"mixingExtruder": "0",
"decouplingTestMinTempRiseBed": 1,
"featureAxisComp": "0",
"axisCompTanXY": 0,
"axisCompTanXZ": 0,
"axisCompTanYZ": 0,
"retractOnPause": 2,
"pauseStartCommands": "",
"pauseEndCommands": "",
"distortionCorrection": "0",
"distortionCorrectionR": 100,
"distortionPermanent": "1",
"distortionEndDegrade": 1,
"distortionXMin": 10,
"distortionXMax": 190,
"distortionYMin": 10,
"distortionYMax": 190,
"sdRunOnStop": "",
"sdStopHeaterMotorsOnStop": "0",
"featureRetraction": "1",
"autoretractEnabled": "0",
"retractionLength": 3,
"retractionLongLength": 13,
"retractionSpeed": 40,
"retractionZLift": 0,
"retractionUndoSpeed": 20,
"filamentChangeXPos": 0,
"filamentChangeYPos": 0,
"filamentChangeZAdd": 2,
"filamentChangeRehome": 1,
"fanKickstart": 200,
"servo0StartPos": -1,
"servo1StartPos": -1,
"servo2StartPos": -1,
"servo3StartPos": -1,
"uiDynamicEncoderSpeed": "0",
"uiServoControl": 0,
"killIfSensorDefect": "0",
"jamSteps": 220,
"jamSlowdownSteps": 320,
"jamSlowdownTo": 70,
"jamErrorSteps": 500,
"jamMinSteps": 10,
"jamAction": 1,
"jamMethod": 1,
"primaryPort": 0,
"numMotorDrivers": 0,
"motorDrivers": [
"t": "None",
"s": "",
"invertDirection": "0",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"invertEndstop": "0",
"minEndstop": "1",
"endstopPullup": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"manualConfig": "",
"zHomeMinTemperature": 0,
"zHomeXPos": 999999,
"zHomeYPos": 999999,
"zHomeHeatHeight": 20,
"zHomeHeatAll": "1",
"zProbeZOffsetMode": 0,
"zProbeZOffset": 0,
"zProbeDelay": 0,
"uiBedCoating": "0",
"langEN": "1",
"langDE": "0",
"langNL": "0",
"langPT": "0",
"langIT": "0",
"langES": "0",
"langFI": "0",
"langSE": "0",
"langFR": "0",
"langCZ": "0",
"langPL": "0",
"langTR": "0",
"langRU": "0",
"accelerationFactorTop": 100,
"bendingCorrectionA": 0,
"bendingCorrectionB": 0,
"bendingCorrectionC": 0,
"supportLaser": "0",
"laserPin": -1,
"laserOnHigh": "1",
"laserWarmupTime": 0,
"defaultPrinterMode": 0,
"laserPwmMax": 255,
"laserWatt": 2,
"supportCNC": "0",
"cncWaitOnEnable": 300,
"cncWaitOnDisable": 0,
"cncEnablePin": -1,
"cncEnableWith": "1",
"cncDirectionPin": -1,
"cncDirectionCW": "1",
"cncPwmMax": 255,
"cncRpmMax": 8000,
"cncSafeZ": 150,
"startupGCode": "",
"jsonOutput": "0",
"bedLevelingMethod": 0,
"bedCorrectionMethod": 0,
"bedLevelingGridSize": 5,
"bedLevelingRepetitions": 5,
"bedMotor1X": 0,
"bedMotor1Y": 0,
"bedMotor2X": 200,
"bedMotor2Y": 0,
"bedMotor3X": 100,
"bedMotor3Y": 200,
"zProbeRequiresHeating": "0",
"zProbeMinTemperature": 150,
"adcKeypadPin": -1,
"sharedExtruderHeater": "0",
"extruderSwitchXYSpeed": 100,
"dualXAxis": "0",
"boardFanSpeed": 255,
"keepAliveInterval": 2000,
"moveXWhenHomed": "0",
"moveYWhenHomed": "0",
"moveZWhenHomed": "0",
"preheatTime": 0,
"multiZEndstopHoming": "0",
"z2MinMaxPin": -1,
"z2MinMaxEndstop": 0,
"extruderIsZProbe": "0",
"boardFanMinSpeed": 0,
"doorPin": -1,
"doorEndstop": 0,
"zhomePreRaise": 0,
"zhomePreRaiseDistance": 10,
"dualXResolution": "0",
"x2axisStepsPerMM": 100,
"coolerPWMSpeed": 0,
"maxFanPWM": 255,
"raiseZOnToolchange": 0,
"distortionLimitTo": 2,
"automaticPowerup": 0,
"hasTMC2130": "0",
"TMC2130Sensorless": "0",
"TMC2130Steathchop": "1",
"TMC2130Interpolate256": "1",
"TMC2130StallguardSensitivity": 0,
"TMC2130PWMAmpl": 255,
"TMC2130PWMGrad": 1,
"TMC2130PWMAutoscale": "1",
"TMC2130PWMFreq": 2,
"TMC2130CSX": -1,
"TMC2130CSY": -1,
"TMC2130CSZ": -1,
"TMC2130CSE0": -1,
"TMC2130CSE1": -1,
"TMC2130CSE2": -1,
"TMC2130CSE3": -1,
"TMC2130CSE4": -1,
"TMC2130CurrentX": 1000,
"TMC2130CurrentY": 1000,
"TMC2130CurrentZ": 1000,
"TMC2130CurrentE0": 1000,
"TMC2130CurrentE1": 1000,
"TMC2130CurrentE2": 1000,
"TMC2130CurrentE3": 1000,
"TMC2130CurrentE4": 1000,
"TMC2130CoolstepTresholdX": 300,
"TMC2130CoolstepTresholdY": 300,
"TMC2130CoolstepTresholdZ": 300,
"microstepX": 16,
"microstepY": 16,
"microstepZ": 16,
"microstepE0": 16,
"microstepE1": 16,
"microstepE2": 16,
"microstepE3": 16,
"microstepE4": 16,
"parkPosX": 0,
"parkPosY": 0,
"parkPosZ": 30,
"emergencyParser": -1,
"hostRescue": "1",
"MAX31855SwCS": -1,
"MAX31855SwCLK": -1,
"tempGain": "0",
"hasMAX6675": false,
"hasMAX31855": false,
"hasMAX31855SW": false,
"hasGeneric1": false,
"hasGeneric2": false,
"hasGeneric3": false,
"hasUser0": false,
"hasUser1": false,
"hasUser2": false,
"numExtruder": 1,
"version": 100.4,
"primaryPortName": ""
This defines max. start/end speed and how much you must reduce speed on direction changes.
That is the number of segments needed per second of move.
So many segements are stored per move at maximum.
Path planning goes only over moves at max. 16 moves. But if a move needs more then DELTASEGMENTS_PER_PRINTLINE segments one move can occupy several moves.
Now at best you can buffer 16 * 20 = 320 segements which is enough for 320/180 = 1.78 seconds of movement at it's best. Espeically on curves you have less usage since short moves don't need all.
At first I'd reduce DELTA_SEGMENTS_PER_SECOND_PRINT - not sure how much you can handle on 8 bit. Due boards can handle 600 but are 10 times faster. If computation eats too much cpu it is irrelevant what you want. Also this gives longer look ahead. Normally long moves should rech full speed if acceleration allows it on the distance. If you have sharp direction changes at end of move it will also slow down more then for small direction changes.
I changed the Delta Segments per second and it really helped a lot.
It is still noticeable that the printer slows down but it is much less drastically.
This works as long as the straight line ist not too long.
When the Line become slonger than ~95mm the printer does not extrude but also not slow down.
This is a picture of a Test where it ignored the long straight line but first after 2 layers.
Even longer straight paves are ignored from the start and a travelled in normal speed but without extruding.
For the long run we will get an arduino due to get the best out of the mechanics.
meaning if any move extrudes more then this it will ignore extrusion, so guess you triggered that. This is to protect for involuntary moves when a print in absolute coordes ended at 4000 and then E0 is send for example.
