do i need to install repetier firmware to use on linux with mini fabricator tiny boy?
if so how do i install the firmware?
  • Every printer needs a firmware. Prebuild printers normally come with firmware already burned so it should work right out of the box once you know the port and baud rate. If not read the firmware instructions here
    and use the onlince config tool from our download page for easy setup.
  • No, the mini fabricator tiny boy has the Marlin 1.0.1 installed, so you can use it with Repeater-Host right as it is.
