MKS Gen l 1.0 for Da vinci 2.0 Duo
Hello everyone,
I redeemed my DAvinci duo 2.0 A from its mainboard at the weekend and installed an MKS Gen L 1 V
With the Repetier Tool I tried to create a firmware that didn't work that well
On the first try, the Z motor turned but the limit switch didn't respond
I then checked this and it is an optical switch and then changed it to electrical in the firmware
Both attempts to upload this firmware can have an error message several times, then I changed the USB port and then the firmware could be uploaded, but nothing moves anymore
ich habe mit dem Tool meine Drucker nochmal flashen wollen aber es kommt diese fehlermeldung
1. Der Drucker nutzt nicht COM17 \
2. Eine andere Software z.b. Repetier-Server ist bereits mit dem Port verbunden. Hier die Verbindung der anderen Software erst stoppen und dann hochladen.
