CoreXY limited movements.
I am currently building a 3D printer, I'm using the system moves "core XY". I'm working with repetier-firmware and repetier-host. When the dimensions of the printer is set from the configuration tool (with anything value) in repetier-host using the manual control only moves to 200 units on each axis (x-axis and y-axis).
i try to use other software (mattercontrol and pronterface) and its the same, i change the value of X_MAX_LENGTH and Y_MAX_LENGTH in the configuration.h but the result is the same
