Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Server
Bug Reports
New display of Print Speed on version 1.4.3 labeled F:. Should be labeled as S: for speed
jgbrown54
November 2022
in
Bug Reports
Is this new display for Flow or for Speed? It appears to be the print speed, but it is labeled F: for Flow instead of S: for speed.
Repetier
November 2022
It is named F because it is the value of the G0/G1 F value which is speed. But in g-code the speed is always send as F parameter.
jgbrown54
November 2022
That explains it. Especially since the display is a display of what the commands say to do, not what the printer is actually doing.
So, changing the Speed with the selection at the top of the screen will not have an effect on F:?
Repetier
November 2022
Exactly speed multiplier has no effect - it is the F value send and only printer internally multiplies it with speed multiplier. Also you need to send a new F value for it to change. So it is the last F value send to printer.
Sign In
or
Register
to comment.
