[Sparkcube XL] MABL Problem
i hope i'm in the right Category.
I'm trying to configure the MABL of the Sparkcube XL. After sending the "G32 S2" Command, the printer starts to measure the Distance and the motors changing the position of the bed. After 5 trys, the printer runs into an error. Does anyone can help me with the configuration?
Here is the Log:
15:31:30.743 : X:400.00 Y:400.00 Z:0.000 E:0.0000
15:31:46.473 : Z-probe:13.350 X:60.00 Y:60.00
15:31:53.824 : Z-probe:14.689 X:340.00 Y:60.00
15:32:00.702 : Z-probe:11.797 X:60.00 Y:338.00
15:32:00.706 : plane: a = 0.0048 b = -0.0056 c = 13.3982
15:32:00.706 : Correction Motor 2:0.753
15:32:00.711 : Correction Motor 3:3.067
15:32:03.077 : CurrentZ:13.40 atZ:12.00
15:32:09.218 : Z-probe:11.763 X:60.00 Y:60.00
15:32:15.013 : Z-probe:10.955 X:340.00 Y:60.00
15:32:22.162 : Z-probe:12.449 X:60.00 Y:338.00
15:32:22.166 : plane: a = -0.0029 b = 0.0025 c = 11.7882
15:32:22.170 : Correction Motor 2:-0.146
15:32:22.173 : Correction Motor 3:-1.543
15:32:23.231 : CurrentZ:11.79 atZ:13.40
15:32:29.498 : Z-robe:12.062 X:60.00 Y:60.00
15:32:35.916 : Z-probe:12.454 X:340.00 Y:60.00
15:32:42.908 : Z-probe:12.064 X:60.00 Y:338.00
15:32:42.913 : plane: a = 0.0014 b = 0.0000 c = 11.9774
15:32:42.913 : Correction Motor 2:-0.342
15:32:42.916 : Correction Motor 3:0.336
15:32:43.310 : CurrentZ:11.98 atZ:11.79
15:32:49.740 : Z-probe:12.464 X:60.00 Y:60.00
15:32:56.196 : Z-probe:12.529 X:340.00 Y:60.00
15:33:03.392 : Z-probe:12.569 X:60.00 Y:338.00
15:33:03.397 : plane: a = 0.0002 b = 0.0004 c = 12.4279
15:33:03.401 : Correction Motor 2:-0.185
15:33:03.401 : Correction Motor 3:-0.072
15:33:03.544 : CurrentZ:12.43 atZ:11.98
15:33:10.159 : Z-probe:12.911 X:60.00 Y:60.00
15:33:16.737 : Z-probe:12.825 X:340.00 Y:60.00
15:33:23.946 : Z-probe:12.602 X:60.00 Y:338.00
15:33:23.951 : plane: a = -0.0003 b = -0.0011 c = 12.9965
15:33:23.955 : Correction Motor 2:0.455
15:33:23.955 : Correction Motor 3:0.306
15:33:24.393 : CurrentZ:13.00 atZ:12.43
15:33:24.884 : X:60.00 Y:338.00 Z:12.996 E:0.0000
15:33:24.889 : RequestStop:
Thank you.
Greets
  • What is the error? I don't see one only improving bed leveling. So looks fine. It might be that MABL stops after 5 iterations. But you should be able to restart it if you want more.
    Are the 3 test points close to your z spindles? Isn't the back one in the middle while you test the edge?
  • Hi! Habe inzwischen gesehen dass das Forum nicht nur englischsprachig ist. Also mache ich jetzt auf deutsch weiter. Ja, die Testpunkte sind relativ nahe an den Z-Spindeln. Die Punkte befinden sich wie auf den Abbildungen vorne links, vorne rechts & hinten links. Mein Problem ist, dass das MABL nie wirklich fertig wird. Nach den 5 Versuchen bricht es mit der Meldung "19:32:51.357 : RequestStop:
    19:32:53.850 : fatal:G32 leveling failed! - Printer stopped and heaters disabled due to this error. Fix error and restart with M999." ab. Wenn ich es neustarte macht es wieder 5 Versuche. Ich bin langsam wirklich am verzweifeln..
    Danke im Voraus!
  • Das ist kein echter Fehler. Tests sind auf BED_LEVELING_REPETITIONS Runden begrenzt und wenn die Fehlertoleranz nicht unter 0.00025 for plane a und b fällt, gibt es dann diese Meldung.
    Du sagst hinten hast do links die Spindel. Heist das rechts gibt es auch eine Spindel? Weil die Dreipunktmessung ist für systeme mit 3 Spindeln da 4 Spindeln statisch überbestimmt sind und das Bett verbiegen, wir aber von einer statisch bestimmten Lagerung ausgehen. Dies kann leicht dazu führen, das korrekturen falsch abgeschätzt werden. Auch sind die Motorpositionen hier wichtig, da die gemessene Schiefstellung auf die Motorposition extrapoliert wird. Falsche koordinaten führen auch zu falscher korrektur.
