How to unregister OEM Server and remove license key before building an image for distribution.
As I'm working on configurations for my OEM version of Repetier Server, I need to register it as an OEM version, make some changes, unregister, remove the registration, and then create an image. How do I remove the license key after it is unregistered? If I delete the key and then reboot the server, it shows the old key. The second issue, which hasn't come up yet, is that I might register the server and then due to a failure, need to reload or replace the server. But then I can't use the registration key because it says it is already registered. Is there a way to unregister the key so it can be used on another server?
Linux Ambian
Most important is key.sql as it also contains uuid which should be unique, server name and some more settings. Then users, network settings, gpio settings etc in case you have not set some special settings into them. We don't so we delete them for empty start.
Also remember to reset ssh key so every instance has own key and reset wifi settings and add marker to expand file system on first startup in case the sd card is bigger than the original.
