I am trying to install the firmware onto a pico to work as brains of printer. Can i use the pico, or should I switch to arduino as the microcontroller?
Pico is using a different board architecture that is not supported. But also not all arduino boards are supported, so please check first if it is compatible with the firmware version you want to use.
