bltouch error
I'm having a Problem with my bl touch sensor. When I tell the printer to
auto level or to z home it does everything that it is supposed to, but
when the probe triggers it drops again by itself hitting the build plate
and sometimes triggering again. Thus sending
an error.
I tried setting a wait command in the Start script or the after every
probe script, and setting a delay in the config but those delays trigger
after the probe hits again, and the build plate has moved away.
I guess that I have the problem because my build plate is to slow and can't move out off the way in time.
I'm running a Radds 1.6 due and the Repetier version 1.0.4
Any help or advice welcomed,
MATT
