New server version causes crashes with all printers
Just updated to the latest version for Repetier Server and now I cant run a single print. On all my machines as soon as I kick off a print they all keep disconnecting and reconnecting.
This has shut down my whole farm and I have no option to roll back the changes. Please can you advise what to do here as I have a big backlog of orders I need to get through.
  • Did you change image or server version? You can revert to older version by manually installing the old package file. There might be some issues with viewing gcode as they have changed the format a bit.
    But can you say what exactly the issue is? Is the server restarting due to some errors or are the printers it self reconnecting for some reason like EMI/Underpower. In new image we used latest bullseye compared to buster before. But at least on our systems it had no issues. YOu see this easily in server.log and syslog downloadable in printer logs for example.
  • I simply updated the server version through the UI. I can send commands fine such has heating the bed or moving around the printer etc. But when I try to print a file I just keep getting connect and disconnect spam.
    1 machine is running skr 1.4, 1 skr 2 and the other machine running skr mini. All were absolutely fine on version 1.3.0
  • edited September 23
    Send:14:41:39.542: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:39.552: Error:No Checksum with line number, Last Line: 12 Recv:14:41:39.554: Resend: 13 Recv:14:41:39.574: Waiting for resend requests finished. Starting resends ... Send:14:41:39.574: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:39.584: Error:No Checksum with line number, Last Line: 12 Recv:14:41:39.586: Resend: 13 Recv:14:41:39.605: Waiting for resend requests finished. Starting resends ... Send:14:41:39.605: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:39.623: Error:No Checksum with line number, Last Line: 12 Recv:14:41:39.627: Resend: 13 Recv:14:41:39.646: Waiting for resend requests finished. Starting resends ... Send:14:41:39.646: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:39.659: Error:No Checksum with line number, Last Line: 12 Recv:14:41:39.661: Resend: 13 Recv:14:41:39.680: Waiting for resend requests finished. Starting resends ... Send:14:41:39.680: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:39.692: Error:No Checksum with line number, Last Line: 12 Recv:14:41:39.694: Resend: 13 Recv:14:41:39.715: Waiting for resend requests finished. Starting resends ... Send:14:41:39.715: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:39.733: Error:No Checksum with line number, Last Line: 12 Recv:14:41:39.740: Resend: 13 Recv:14:41:39.759: Waiting for resend requests finished. Starting resends ... Send:14:41:39.760: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:39.770: T:23.69 /0.00 (978.62) B:25.91 /0.00 (975.00) @:0 B@:0 Recv:14:41:39.781: Error:No Checksum with line number, Last Line: 12 Recv:14:41:39.783: Resend: 13 Recv:14:41:39.803: Waiting for resend requests finished. Starting resends ... Send:14:41:39.803: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:39.815: Error:No Checksum with line number, Last Line: 12 Recv:14:41:39.817: Resend: 13 Recv:14:41:39.837: Waiting for resend requests finished. Starting resends ... Send:14:41:39.837: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:39.849: Error:No Checksum with line number, Last Line: 12 Recv:14:41:39.851: Resend: 13 Mesg:14:41:39.851: Receiving only error messages. Reset communication for printer Ender 5. Mesg:14:41:40.980: Dtr: true Rts: true Mesg:14:41:40.980: Connection continued Send:14:41:40.991: N14 M82 ;absolute extrusion mode Send:14:41:40.991: N15 M503 ;print out settings Send:14:41:40.991: N16 G21 ;metric values Send:14:41:40.991: N17 G90 ;Absolute positionning Send:14:41:40.991: Slow command added:M190 S55.0 ; Set bed temp and wait to be reached Send:14:41:40.991: N18 M190 S55.0 ; Set bed temp and wait to be reached Send:14:41:40.991: Slow command added:G28 ;Home Send:14:41:40.991: N19 G28 ;Home Send:14:41:40.992: N20 M114 Send:14:41:40.992: N21 G92 E0 ;Reset Extruder Recv:14:41:40.995: 3.69 /0.00 (978.62) B:25.82 /0.00 (975.44) @:0 B@:0 Recv:14:41:41.008: Error:Line Number is not Last Line Number+1, Last Line: 12 Recv:14:41:41.010: Resend: 13 Recv:14:41:41.029: Waiting for resend requests finished. Starting resends ... Send:14:41:41.029: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:41.041: Error:No Checksum with line number, Last Line: 12 Recv:14:41:41.043: Resend: 13 Recv:14:41:41.063: Waiting for resend requests finished. Starting resends ... Send:14:41:41.063: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:41.075: Error:No Checksum with line number, Last Line: 12 Recv:14:41:41.077: Resend: 13 Recv:14:41:41.097: Waiting for resend requests finished. Starting resends ... Send:14:41:41.097: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:41.109: Error:No Checksum with line number, Last Line: 12 Recv:14:41:41.111: Resend: 13 Recv:14:41:41.130: Waiting for resend requests finished. Starting resends ... Send:14:41:41.130: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:41.142: Error:No Checksum with line number, Last Line: 12 Recv:14:41:41.144: Resend: 13 Recv:14:41:41.163: Waiting for resend requests finished. Starting resends ... Send:14:41:41.163: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:41.174: Error:No Checksum with line number, Last Line: 12 Recv:14:41:41.176: Resend: 13 Recv:14:41:41.196: Waiting for resend requests finished. Starting resends ... Send:14:41:41.197: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:41.207: Error:No Checksum with line number, Last Line: 12 Recv:14:41:41.209: Resend: 13 Recv:14:41:41.228: Waiting for resend requests finished. Starting resends ... Send:14:41:41.229: Resend: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C Recv:14:41:41.240: Error:No Checksum with line number, Last Line: 12 Recv:14:41:41.242: Resend: 13 Mesg:14:41:41.243: Receiving only error messages. Reset communication for printer Ender 5. Mesg:14:41:42.366: Dtr: true Rts: true Mesg:14:41:42.366: Connection continued Send:14:41:42.377: Resend: N14 M82 ;absolute extrusion mode Recv:14:41:42.381: 3.75 /0.00 (978.50) B:25.88 /0.00 (974.94) @:0 B@:0 Recv:14:41:42.393: Error:Line Number is not Last Line Number+1, Last Line: 12 Recv:14:41:42.395: Resend: 13 Mesg:14:41:42.396: Receiving only error messages. Reset communication for printer Ender 5. Mesg:14:41:43.516: Dtr: true Rts: true Mesg:14:41:43.516: Connection continued Send:14:41:43.527: Resend: N15 M503 ;print out settings Recv:14:41:43.531: 3.78 /0.00 (978.44) B:25.94 /0.00 (975.12) @:0 B@:0 Recv:14:41:43.543: Error:Line Number is not Last Line Number+1, Last Line: 12 Recv:14:41:43.545: Resend: 13 Mesg:14:41:43.546: Receiving only error messages. Reset communication for printer Ender 5. Mesg:14:41:44.676: Dtr: true Rts: true Mesg:14:41:44.676: Connection continued Send:14:41:44.687: Resend: N16 G21 ;metric values Recv:14:41:44.691: 87 /0.00 (978.25) B:25.85 /0.00 (974.94) @:0 B@:0 Recv:14:41:44.703: Error:Line Number is not Last Line Number+1, Last Line: 12 Recv:14:41:44.705: Resend: 13 Mesg:14:41:44.706: Receiving only error messages. Reset communication for printer Ender 5. Offl:14:41:44.709: Ignored (offline):M73 P2 R483 Q2 S483 Offl:14:41:45.606: Ignored (offline):M77 Mesg:14:41:45.837: Dtr: true Rts: true Mesg:14:41:45.837: Connection continued Send:14:41:45.848: Resend: N17 G90 ;Absolute positionning Recv:14:41:45.852: 9 /0.00 (978.62) B:25.94 /0.00 (975.31) @:0 B@:0 Recv:14:41:45.864: Error:Line Number is not Last Line Number+1, Last Line: 12 Recv:14:41:45.866: Resend: 13 Mesg:14:41:45.867: Receiving only error messages. Reset communication for printer Ender 5.
  • Bah seems the forum doesnt respect line endings... either way thats basically whats happening. Nothing has changed from my end other than simply clicking update on the server. Might I suggest a rollback function on the sever. The last thing I want to do now is to spend all afternoon trying to roll it back and set it all back up again from scratch.
  • Im going to roll back until I can fix this on a sandbox. If I ssh into the pi can I just install version 1.0.3 over the last one? How can I do that what commands do I need? Im a pro licence holder btw.
  • Note to future self and others.
    To downgrade SSH to the pi,
    Then run the following to get the old version:
    Now run the following to install the old version:
    sudo dpkg -i Repetier-Server-1.3.0-Linux.deb
    This will install the old version over the new one. This fixed all those issues for me. I really wish you guys would do a bit more testing on your releases. The bug report area is full of issues relating to 1.4.x
    Thankfully I was easily able to roll back. I think ill use a separate pi for future updates just incase all hell breaks loose again.
  • We test until we get no problems in testing, but there are always edge cases. I think I found your problem:
    Send: N13 M75 CE5_16g_Mag_v3_9 Sunlu PLA 109g lw 0.4mm lh 0.28mm flow 100% if 40% ext1 215.0C bed 55.0C
    has already 98 byte und there will be also the checksum added. I think marlin line limit is 96 byte so it does not fit generating the error message. So this error will only be visible with extraordinary long file names.
    The change causing this was that in marlin.xml in firmare folder we changed
    M75
    into
    M75 {{job.name}}
    To show running job on printer. Will now reduce this to max. 20 chars to prevent such an overflow. So server is ok just the name causes overflow in marlin breaking communication. And too many errors then finally disconnect.
    So thanks for providing the info for the reason so we can catch this in 1.4.3.
  • Thanks for the fast response! Appreciate it. Sorry for being crabby, I was stressing out about my orders. Still love repetier though! Will eagerly await 1.4.3
