E3D BigBox
I have a E3D BigBox Dual and considering giving Repetier a go. The controller is a RUMBA board. My setup is a bit different than regular BigBox as I use two Z stepper drivers, Z and Z1 where Z1 is connected to RUMBA motor out E2.
The BigBox has two lead screws centered on the left and right side of the bed and a smooth rod in each corner to make it as level/tram as possible. Then I have the usual 4 corner screws to manual level the bed. I use manual Mesh Bed Levling today to compensate for sag in the rods holding the carriage. I can get 0.15mm difference in the middle of the bed. The Z-probe is only used for homing today.
If anyone could enlighten me I would be very happy.
- The BigBox has a dump bucket / docking area where the extruder can go Y_MAX + 40, It does not have much room in the X axis so whenever there is a tool change between extruders it must not move along X. Will this be a problem?
- Does Repetier support dual Z endstops to level the bed?
- Does Repetier support the Z-probe to level the bed with dual Z stepper drivers?
- Does it support a grid Z-probe leveling together with dual Z stepper drivers?
- It looks like what I'm really looking for is an automated grid leveling saving a "distortion map". This sounds like Marlins Mesh Bed Leveling (MBL)
Regards
Stian
Should P1 be front (towards me) left corner,
P2 front right corner and
P3 back left corner?
Probably just something I do not understand but why do you have the option of a grid autolevel (G32)? What is the point with a autolevel grid when the distortion map will take care of the bumps/sag? Wouldn't the BED_LEVELING_METHOD 0 or 2 suffice?
Bed coating (Z_PROBE_Z_OFFSET) is 0. My Config.
