Print and temperature freeze stuck in a loop
Hi, I have a Printrbot Plus connected to a raspberry pi running Repetier-Server 0.80.
I just switched to the SD image to add a raspberry cam to my setup but since then I can't launch any new print.
Here's how it goes:
1 - launch print
2 - extruder/bed heat up fine
3- print start and autoleveling takes place
4- print and temperatures functions freeze and nothing moves anymore.
At this point, I can stop the print that's frozen but it won't give me back command of the extruder or temperatures. The printer's temperatures monitor on the server's home page doesn't shows anything either.
I think I found the cause when I looked at the consol which seems to be stuck into a loop but I don't know what to make of it:
1:13:22.665: Resend: 67
1:13:22.681: Error:Line Number is not Last Line Number+1, Last Line: 66
1:13:22.681: Resend: 67
1:13:22.698: Error:Line Number is not Last Line Number+1, Last Line: 66
1:13:22.698: Resend: 67
1:13:22.698: Resend after 141ms
1:13:22.713: Error:No Checksum with line number, Last Line: 66
1:13:22.713: Resend: 67
1:13:22.725: Error:Line Number is not Last Line Number+1, Last Line: 66
1:13:22.725: Resend: 67
1:13:22.742: Error:Line Number is not Last Line Number+1, Last Line: 66
1:13:22.742: Resend: 67
1:13:22.759: Error:Line Number is not Last Line Number+1, Last Line: 66
etc...
Any idea ?
