Different step for axis
Good evening.
Finished editing my delta printer I realized to have a diameter of a pulley smallest.
In firmaware not able to set a number of steps for different axis.
#define AXIS_STEPS_PER_MM ((float)(MICRO_STEPS * STEPS_PER_ROTATION) / PULLEY_CIRCUMFERENCE)
#define XAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
#define YAXIS_STEPS_PER_MM 107
#define ZAXIS_STEPS_PER_MM AXIS_STEPS_PER_MM
What part of code I have to change for a number of steps to diferent axis?
Thank you.
Excuse me for the English but use google translator.
Some indication where modify the firmware as required from me?
Or where can I find documentation on the development of the firmware?
Thank you.
